Results 1 to 8 of 8
Thread: Diy heads porting and polishing
    Vy spack v6
    Sep 2011
    Default Diy heads porting and polishing
    How hard is it to port, polish, match and face heads yourself?
    vyseriesII's Avatar
    vyseriesII is offline The V6 is MACEd
    2004 Vy S Series II
    May 2011
    Unless you got the right gear and know what your doing there's a lot of chance for things to go wrong. Not saying someone couldn't do it successfuly but id rather pay someone to do it.
    Vy spack v6
    Sep 2011
    If i were to do that to the super6 heads, this will give me more mid range to top power than low down,
    Is this right?
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    I did my heads using a Standard Abrasives porting kit, a Super Shit die grinder and many many hours. You also pretty much need to get your valve seats re-cut afterwards to be safe.
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Get some sand, take off everything attached to the throttle body so you can get unrestricted access to it, start the engne, rev to 6000rpm and feed the sand into the WOT....
    Seriously, as already said unless you have the correct tools have practiced hand porting heads... it's going to be difficult and possibly stuff the heads up. Also head work should be in conjuction to other mods like a CAM and the head work should match which does take a bit of knowledge.
    There are plenty of article on the web(Google is your friend) and if your really stuck on doing it yourself get yourself a pair of second hand heads from a wrecker and go nuts.... this way of you stuff them up you can always put your orinigal back on.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Unless you have a fair idea of what your doing a home port job is really just a good clean up with emphasis in minimal metal removal. For a stock cam'd engine you want to maintain a small port/runner to keep the airspeed up. if you hog out the port in one particular are it will loose a lot of airspeed causing all sorts of issues i.e. a loss of torque. Big ports/large cross section runners are only good for engines with big cams and lots of revs where low rpm performance and throttle response isn't required.
    There are certainly gains to be had on a stockish type engine with pocket ported heads/cleaned up runners.
    Body by Holden, Soul by Brock
    the Legend will live forever
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    Its def a big job to do it properly. I did stacks of research on what to shape and where before i did mine, then had them faced etc and flow benched to double check how close they were.
    I spent a lot of time doing it, and thats using all the proper tooling. Was a great experience though, and I got some fantastic gains on a cammed engine
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Quote Originally Posted by Beauzza View Post
    Is this right?
    Are you planning to put L67 heads onto an L36 with the stock L36 manifold, or are you installing the LIM and supercharger from a L67?
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
  1. Pre ecotec heads. porting and CFM ?
    By NOT 38 in forum V6 Development And Modification
    Last Post: 09-06-2011, 12:12 PM
  2. Porting Heads and polishing...
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-08-2009, 09:50 PM
  3. cost of porting heads
    By 5.0L VS Ute in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-06-2008, 01:28 PM
  4. Porting Vn heads
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-07-2006, 10:51 PM
  5. Is porting ok in my set up???
    By VS-commy87 in forum Car Audio
    Last Post: 22-11-2005, 12:49 AM
