Results 1 to 12 of 12
Like Tree2Likes
  • 2 Post By immortality
Thread: turbo or supercharger
    1988 Vn Executive
    Aug 2011
    ferntree gully
    Default turbo or supercharger
    hey guys i'm wanting to work a vn motor v6 and i'm just wanting get some opinions on which pulls off more power
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    1988 Vn Executive
    Aug 2011
    ferntree gully
    could you give me a little list on internal upgrades and can you run a double throttle body mankifoldn with a turbo
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    Turbo
    dont worry about internals just get a tune.
    Ditch the 2 throttle body idea just run one ported single
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    turbos generate alot more heat and heat related problems to other components , turbo's will give better high speed running where as super charging will be more responsive of the line and thru the gear changes , all depends on what you wish to do with the engine , low comp's are required for turbo's and intercooling is a must for high boost use , twin throttle bodies arn't much use when using forced induction as the manifold is pressurized and not so reliant on airflow .
    consider what you want your engine to do and intend use for the car
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    As above, No point having a TTB on any force inducted car, they are fed enough air with a stock TB.
    You WILL need to replace internals if you plan on running hi boost on an engine and dont expect it to last if its got plenty of K's on it.
    I tried to tell my mate this but he didn't listen and his engine lasted about 2 weeks then he replaced it and then the other engine went pop as well..
    Sure, you can probably run it on low boost and be safe, but whats the point of bolting up a turbo if its only being used at 1/4 of its potential?
    He just installed forged internals and its held up well but now his gearbox has had it.
    The tune is a big one, they cost a shit load. Every car is different even if they are the same make and model so be prepared to pay from $800 to $1000 just for a Dyno tune.
    If anyone tells you its less, well they either have no idea what they are on about or the tune they have is rubbish.
    But Id always choose a turbo over a supercharger, its all personal preference really but I just find the neck snapping power range in a turbo car is more satisfying then any supercharger. (in respect to the engine its on that is)
    VR V6 manny' wagoon
    Jan 2011
    With these lovely old V6s, they have rock solid bottom ends which last and last if you keep the oil to them and don't spend much time revving their titties off. The big let down is the heads which are 'slow' and heavy as heck.
    My suggestion is to get a nice old grandpa motor, put some flowing after market heads on it, chip it, cam it, pipe it, dump it, look after it and give it hell.
    My guess is alot of you guys on here are not quite old enuf to remember what a street full of cammed-up cars is like, but it fricking rocks.
    And with fuel injection and engine management systems, they don't have to be so undrivable as a carb'ed beasty.
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    Quote Originally Posted by sticksicks View Post
    Ahhh, nothing quite beats the sound of a big hp, big cammed, n/a engine trying to shake itself apart at the lights. Brings back memories and a slight tear to my eye.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by 304runner View Post
    There is a guy on SC running 19 psi into a stock bottom end VR Buick engine. Been running fine like that for some time. It only blew a head gasket when the waste gate failed causing a boost spike. Delcowizzid has been working on a V6 powered VB commodore, again stock bottom end (VN s1 engine) V6 running 11.7sec 1/4 @ 121mph. The secret is in the tune combined with a good fuel system and running a ecotec oil pressure spring to ensure good oil pressure.
    Body by Holden, Soul by Brock
    the Legend will live forever
    VR V6 manny' wagoon
    Jan 2011
    In Adelaide I remember when Rundle street was often Rumble st on summer satdy nights, jeez it was good. Kingsy's, Escorts, Centuras, GTs even little Mazdas all going rump rump rump. Turbos are great but too quiet at idle.I've had older fellas tell me how when they were lads you could hear the supercruises coming from miles away!! Bit like a gaggle of goons on Harleys, but better sounding )))))))))))
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Thanks for making me laugh at your turbo's are quiet at idle comment.
    VRCALAISS is offline Banned
    94 VR CALAIS 3.8L V6
    Jan 2011
    Morayfield,QLD
    burn vn v6,start with l67 moar power for less moneys.
  1. turbo or supercharger?
    By orthaeeoul in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-07-2009, 10:00 PM
  2. Supercharger or Turbo
    By Ganzer in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-05-2006, 10:42 AM
  3. Turbo and Supercharger
    By HeadKracker in forum General Discussion
    Last Post: 31-12-2005, 12:34 PM
  4. Confused and unsure...turbo/supercharger/stock turbo?
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-07-2005, 09:51 PM
