Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By vyseriesII
Thread: Ecotec - Where can I get it MAFless tuned???
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    Default Ecotec - Where can I get it MAFless tuned???
    As the title says,
    Looking at getting it MAFless tuned, I'm probably going to need to get it all made up with silicon connectors and stuff but besides that..
    Anywhere around Dandenong/Cranbourne area? I don't mind doing a little travel, aslong as they have good results and have done alot of them.
    Cheers.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    any reason you want it mafless?
    afaik, emotecs dont respond to a mafless tune the way an ls1 does. would be worthwhile if you're going forced induction
    Oct 2009
    S.E VIC
    Mafless has had a few decent results near the 160RWKW mark, i'm pretty sure it would be only a little over with MAF anyway.
    I don't mind if it gets tuned with MAF, even a recommendation there would be great.
    I don't plan on going FI, but if a turbo comes up cheap enough it'll happen.
    Mar 2008
    Kyle,
    Electronic Auto in Epping would be able to do a MAFless tune for you if you wanted. In saying this though getting it done will be exxy, so I would just stick with a genuine larger MAF if you wanted to upgrade this.
    Cheers,
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    Oct 2009
    S.E VIC
    No worries Steve, I'll give them a call for pricing. Do you know if they use delco or after market?
    VY SII HBD Calais L67
    Dec 2006
    I also tune MAF or MAP on these. I'd suggest sticking with a MAF as going to MAP costs more and the stock MAF is a good bit of gear that won't be out of range in any way. I could easily fit an LS1 MAF to the car which has a larger internal diameter to improve the intake a little but again, not really needed
    VYII Calais L67
    VS GTS & VT XU6
    May 2011
    but be careful if you just go a larger maf and no tune you will burnout our auto
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Say what?
    Allowing more air flow into the engine burns out the auto? Look out everyone that has a CAI on their car.
    Visit my Facebook page
    Oct 2009
    S.E VIC
    Nice so my manual car will burn out it's auto..
    I thought the CAI gave the diff gears air to breathe?
    Oct 2009
    S.E VIC
    Besides who would put a bigger MAF without a tune?
    vyseriesII's Avatar
    vyseriesII is offline The V6 is MACEd
    2004 Vy S Series II
    May 2011
    Quote Originally Posted by GTS69 View Post
    I'm not sure about that as i don't know all there is about the problems caused by having a bigger maf and no tune. I would of thought there would be air/fuel ratio or some sort of problem?
    VS GTS & VT XU6
    May 2011
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Say what?
    Real funny dude how about you read a little the maf provides the engine with incoming air speed the ecu converts that to a gpm value now if you have ever tuned a car you will know the auto also uses the gpm value from the airflow meter to calculate the amount of line pressure to add to the auto because the auto never runs at full pressure its pressures are dependent on the load on the engine other wise it would heat the auto fluid to much if it ran at full pressure all the time and jolt the car like you were just rear ended when you put it in drive.
    So when you add a ported maf the area increases through the maf and the computer is calculating the in coming air by how much it cools the wires in the maf for a fixed area when you port the maf the air speed is slower and there for cools the elements less this makes the engine think there is less load and reduces fuel to cause the engine to lean and reducess the line pressure in the auto but becaue the engine is under a higher load than it thinks the auto will start to slip a little and burnout much faster.
    Its not a guess its fact ask any LS1 tuner they had this issue when people started throwing ported mafs on the LS1's when they were all the rage and ive done quite alot of research and testing with this in my own cars thanks.
    VS GTS & VT XU6
    May 2011
    Quote Originally Posted by DevilDRake View Post
    obviously not but then i didnt know you had a manual car silly me trying to help a tool good luck o and have a read at whats above you may learn something
    VS GTS & VT XU6
    May 2011
    Many people have do a search you will find heaps plus SS inductions sell them not advising a retune have seen many people buy them fit them and wonder why they have issues
  15. #15
    VS GTS & VT XU6
    May 2011
    Quote Originally Posted by vyseriesII View Post
    yeah mate your right they will mess the Air fuel mixture and cause it to run lean the auto also calculates the line pressure of the maf tables in the ecu have a read at what i posted above will maybe help explain it a little
  16. #16
    Oct 2009
    S.E VIC
    Mate I know about line pressures and stuff, when i had my auto I got the shift pressures and shit all changed.
    Don't know how I'm the tool mate, everyone given advise on this thread can easily read my signature for the mods I've done.
  1. Has your VT/VX/VY Ecotec been tuned?
    By savage1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2009, 04:14 PM
  2. The MAFless ecotec thread
    By VSSECO in forum V6 Development And Modification
    Last Post: 28-08-2009, 07:50 AM
  3. where to get a 5l re chipped and tuned WA
    By Bondy90 in forum Tuning
    Last Post: 17-06-2009, 10:48 PM
  4. Tuned !!!!!
    By Torquen in forum The Pub
    Last Post: 20-08-2008, 10:40 PM
  5. Got My Car Tuned
    By Apeman69 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-11-2007, 02:25 AM
