Will be interesting to see how it holds up and drives.
Custom built hi stall for $395. Can't go wrong.
thats ####ing good after i get my gear i might get one =)
Hi stall is in. I did corvette servos while I was at it. These converters are fantastic. They behave much like a stock converter when your driving like granpa, maybe stalls up about 100-200rpm higher, but when you give it the berries it flashes up to just under 2700rpm. Lock up is still there so cruising on the hi way isn't an issue either. The place where I've noticed the biggest difference is when your cruising at about 60-70kph and mash the pedal, it just flashes up to 2700rpm instantly and slingshots away. I'm very happy. Now bring on the Raptor blower)
Great result. I think a decent converter behind a stockish engine is a great idea when combined with a moderate diff ratio increase as you get the benefits of a great take off from a standing start (much like fitting 4.11's instead of 3.45's) and also great get up and go when cruising and yet still retaining decent cruising revs. thanks for the feedback.
With a blower fitted you'll find that the stall speed will increase a little more but that's not a bad thing at all with a centrifugal blower
cheers
Body by Holden, Soul by Brock
the Legend will live forever
So from my understanding you should buy a torque converter to match the rpm of your max torque, right?
My dyno sheet says 345Nm at 3150rpm, so should I get a 3000rpm torque converter?
Ronald Reagan (1986)
OK so I talked to the torque converter guy today, apparently the impeller and turbine (?) are from an old converter and they are sent away to be heat-treated to stronger than factory and then you get all new bearings, etc.
And they can make them to whatever stall speed you require.
I will be going and talking to him face-to-face tomorrow, and taking my cam specs and dyno sheet so we can work out my optimal speed.
If anyone has any questions to ask him, type them up and I will ask him for you.
For drag racing yes it is ideal. As long as they keep the converter nice and tight so it acts like a stock one until you mash the go pedal and retain the lock up function it should be fine on the street.
If you get enough people interested maybe someone will want to arrange a group buy
Ok just so I don't look like a dick when I ask the guy. In my particular case, my car creates 350Nm of torque at 3150rpm, so if I get a (hyperthetical) 3150rpm torque converter and he has a STR of 2.0, then my transmission input shaft would see 700Nm of torque at 3150rpm? Am I even close, or am I way off?
I will ask him what STR he aims for though.
After reading this.. Selecting The Right Torque Converter By Phil Parsons
I thought about my convertor.. and it's fairly loose and stalls at 3000rpm in my setup. So STR must be fairly high.
Mash the gas from standing still and it's skids on!![]()
"Life's a dare, push yourself, F#@k it you might like it. Live on the edge. It could all stop tomorrow"
- Jimmy Barnes twitter March 2011
3.8T Wagon
Go with a higher stall...grab something around 3200 rpm...its only going to slip up on you around town starting up...once you get driving the converter locks up and and you will rev at the same rpm as you normally would (assuming you are buying a stall with lockup capabilities, which you should unless you are strictly drag racing)
I'm not sure what forum rules are as far as linking to other forums, but here is a link to another v6 site that I am on that I posted a stall faq on (which I stole from a bunch of other sites, anyways it should answer a lot of questions you or others have about stall converters Stall FAQ - FirebirdV6.com/CamaroV6.com Message Board
one thing I highly recommend is getting an extra tranny cooler because your temps will go up drastically with a stall and can kill your trans pretty damn fast...coolers are pretty cheap though.
another benefit to stalls that most people overlook is the shift extensions...basically this just keeps the motor from falling out of a certain rpm range. For my car I wont fall below 5000rpm when the car shifts...so when I did my dyno pull the car started at 5000rpm at 100km/h and went to 185km/h by 6000rpm...torque curve was flat as can be while hp just sky rocketed. On a stock setup the car would normally start from 3500-4000rpm. So basically your getting that power your motor makes up top much earlier.
1996 3800 camaro- Heads/Cam, 4.10 gears, Ford 8.8 rear end, stall, SD tuned
Current best: 13.6 @ 97.05 mph
Current goal: 12's
FWIW, I daily drive a car with a TCI 3800 Super Street Fighter stall for my V6 Firebird. I've got ported heads/intake pretty good camshaft setup and longtube headers. I get around 21-22mpg city driving only with my car. So efficiency isn't too bad even though when it is cold it takes a while for it to finally go into lockout at cruise but most of that can get tuned out but I've been too lazy since I'm going to a manual trans anyway.
I really recommend that you put in a transmission cooler if you do get an aftermarket stall. This will help prolong the life of your entire transmission/stall.
2000 Pontiac V6 Firebird
196hp @ 5600 / 196tq@ 4600
●Whisper Lid●60°Inc. Heads & Intake●Intense S1X Cam●YT 1.7 RR's●FFF LT's●TCI 3800 stall●
So I just went it picked mine up.
Ive never had an issue with lockup like you suggest...although the car does rev a tad higher to get into gear when it is cold. Make sure you tune out the pwm parameters as well, or that will damage your converter.
I dont know what your other guys holden pcm programing looks like, or if you guys are supported by hp tune software as well...if your not Id be interested to see if your programming can work with our pcms, and what kinda support you guys have.
Current goal: 12's
From what I have seen our ecotec engines produce more torque in the low rpm range when compared to the US L36 3800 s2 engines due to our intake manifold design (especially if you have the MACE spacers fitted). With that in mind i'd recommend a lower stall speed converter then the US guys are using.
I think any US forum users who have converted to our intake manifolds would agree
drove through Brisbane in peak hour with a 3000stalli on my vr that had only coil-packs, rebuilt motor recent, stage 1 cam, and full manual auto box.. it just liked to free rev until 1300rpm, but that was any time you drove it from a stop.. after that it was fine, unless you were hard on brakes it didint in-gauge till 3000rpm then.. but i can tell you, they are Lott's more fun! haha
I ended up just getting the 2500rpm, he said for the daily driver that would be better. He gave me the choice of going higher but I didn't think that would be wise, most places I've read up about these, it recommends a stall speed about 600-700rpm less than the peak torque point.
Chargedvx6, he said they try and retain the factory STR.
Sounds like the same as my one. A hell of a lot more fun than a stock stall)
hey scott-95 what diff gears did you run in your vr? or just standard ratio? cheers
Thanks for the feedback. Not sure how they go about retaining stock STR whilst raising the stall speed but I don't build converters for a living lol.
Interested to hear your thoughts after it's fitted. I'd film a few WOT 0-100 runs pre and post install. That way you can time any difference accurately and safely during playback
VYII Calais L67
I would have gone more in depth in the questioning but I was running late for work. To be honest I think the guy I was talking to was one of thier office staff and doesn't work on the stallies themselves, and was just saying stuff he may of picked up from the mech's. Like he was knowledgeable but not in-depth, if you know what I mean.
Just a bit of a update. Now after going from a stock converter and 3.08 diff to a 3.46 and 2500 histall my fuel economy has gone from around 15 ltrs per 100 km to 12.3 around town and on th highway it's gone from 12.3 to 9.7. Just an added bonus I wasn't expecting.
