Results 1 to 12 of 12
Like Tree5Likes
  • 2 Post By aaronevolution
  • 1 Post By letthiswork1
  • 1 Post By Decicrate
  • 1 Post By one_and_only2004
Thread: best mods
    VT S pack
    Feb 2012
    wanneroo
    Default best mods
    hey i have a stock vt s manual and im wondering whats the best and easiest mods i could do to increase peformance
    aaronevolution's Avatar
    aaronevolution is online now Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Easiest mod for performance would be to sell it and buy a new car.
    If that's not an option, try the search button.
    VY ute (2003)
    Jun 2010
    Manly
    Hi Coch.
    Usually people do exhaust, cai, tune, rockers and gears.
    If you search on forums you will get a lot more much more in detail info
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by letthiswork1 View Post
    Hi Coch.
    X2 best advise you'll get!
    VS L67
    Sep 2007
    BrisVagus
    Remove the existing engine and replace it with an L67 and an L67 tune(memcal). Direct bolt in.
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
    VY S Series 2
    May 2010
    i think its safe to assume he's on his P's which generally makes that not really an option
    Apologies to the OP if your not on your P's
    Drawnnite's Avatar
    Drawnnite is online now Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    save money that would be spent on those mods.
    put it towards an 8.
    unless you have lots and lots to chuck at a 6. it isnt going to be a rocket ship.
    however if you want to improve fuel economy performance (tbh id consider that a performance increase)
    Mace Spacers. Extractors (not all but some can) with 2 1/4 stock exhaust.
    i can get 8L per 100. with just the S/C Cai and 12mm Mace spacers. hopeing it gets better witht he extractors (ive read the ones im getting should)
    easiest mod is to remove all the rubbish in your car you dont need.
    baby seats. toolboxes. spare wheels... (seriously dont do that one)
    less weight = less that engine has to haul around.
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I thought extractors where one of the last mods that your meant to do as they don't make much difference?
    I'm no expert but that's what I've read.
    VT V6 Executive Manual
    Oct 2009
    QLD, Molendinar
    i'm on my P's i have a VT manual, i've done: extractors, hiflow cat, 2.5" exhaust, mace 12mm spacers, growler kit, bored and polished TB, yella terra 1.7's, 105# valve springs with locks and retainers to suit, wade 992a cam, crow cams lifters and timing chain, chip torque tune, kings springs and gt shocks, 3.46's LSD. you feel the biggest differences when you do the exhaust system and diff gears. its up to you with the amount of mods you want to do, just make sure you plan ahead.
    walesy's Avatar
    walesy is offline Aint no family cruiser!!!
    Cherry Black WH II Caprice, VS exec wagon
    Jun 2005
    Perth SOR
    hmm scroopy... soopy?
    Going where no late model stato/caprice has gone before.... GAME ON!!
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Quote Originally Posted by walesy View Post
    Not by a long shot my friend...
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    Quote Originally Posted by pjdm1980 View Post
    i believe it all depends.
    from research and talking to lots of people ive come to the conclusion that extractors with the 2 1/4 for a v6 that it is actually pretty good.
    the problem is lots of people go for 2 1/2 systems with their 6's.
    this is larger, which lets gas cool down more. its the whole maths behind it.
    the larger pipes only are effective at high revs and higher speeds. which = racing and so forth (unless you hold it at 3500+ rpm)
    with the smaller pipes (2 1/4) and extractors for low end (which i have ordered) it can improve the lower end alot. (up to 4000rpm and up to about 90kph)
    pretty much if you are going to build a car you would want an exhaust to suit. no point having too little or too much backpressure....
    but when mine eventually goes in (ive order them, now to wait) ill be able to confirm this. (extractors with a stock 2 1/4 set up. which should be super quiet)
    but my reason for this (apart from hole in exhaust) is to try to improve fuel economy (as i drive currently 1000kms a week.. so lot of fuel)
    and the car is built for towing. so hopefully better torque down low will improve it even more.
  1. Blue 202 what are some mods any preofrance mods?
    By calais_crofts in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-02-2011, 02:06 AM
  2. vxV6 mods,best mods to choose?help appreciated
    By benjamino in forum V6 Development And Modification
    Last Post: 11-06-2008, 09:51 AM
  3. Mods to VS V6
    By defyet in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2006, 02:23 AM
Tags for this Thread
