Results 1 to 9 of 9
Thread: Identifying 3.8 V6 Origin...
    Flamenco Guest
    Default Identifying 3.8 V6 Origin...
    Hello all, just a quick query. I'm transplanting a V6 into my Torana LX Hatch but it would be beneficial to know what the engine and transmission I have is out of model-wise...
    I've had a quick look but I'm unsure where to find the engine number/s.
    If it's any clue the rocker covers appear to be plastic coated (the other engine I have - but not using has powdercoated rocker covers).
    Thanks.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by Flamenco
    Thanks.
    the box is the problem lx have trimatics the tunnel in the torry wont fit a hydro to narrow give dello automotive a ring to check merrygould st reavsby nsw
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    Flamenco Guest
    I've got the conversion kit and I know it'll all fit in but I was after some info on identifying the engine if possible...
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    as in what american fwd aust vn/vp s1-vp s2/vr-vs/vy
    Powered By Garrett
    Flamenco Guest
    The model commodore that my engine is from - whether it's a series one, two etc & also where to find the engine number on the block.
    burnz's Avatar
    2010 CRUZE Diesel
    Jun 2005
    springfield
    engin no# arnt muh use
    vn/vp1 top radiator hose rear of block
    vp2/vr top radiator front of block
    vs/vy plastic cover on air intake/3800 ecotek
    vz 3.6 alloy tek
    Powered By Garrett
    Flamenco Guest
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Quote Originally Posted by burnz
    vz 3.6 alloy tek
    Only vn series 1 had the thermostat at the back. Vn series 2 onwards had thermostat housing at the front.
    Flamenco Guest
    I found the engine number (next to water pump on the passenger side), after looking into it further (& taking into account the thermostat position as mentioned above ^) the engine I have is out of a VP... Thanks all.
  1. State Of Origin
    By Julie in forum The Pub
    Last Post: 07-07-2011, 06:41 PM
  2. Need help! Blue motor of unknown origin into VH..
    By frenchyvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-01-2007, 09:37 AM
  3. State of Origin III - the decider
    By _Mukas_ in forum The Pub
    Last Post: 07-07-2006, 05:35 PM
  4. Origin 2 yeeehah !!!
    Last Post: 18-05-2006, 08:08 PM
  5. how good was the state of origin!!!!
    By damo15 in forum The Pub
    Last Post: 31-05-2005, 09:47 AM
