Just wonder approx what id be lookin at for a Race built V6 ??
5000+??? depends what you want in it?
I got quoted approximately $4000 to have my block decked, honed, and bored.
Heads flowed and ported majorly.
ACL race rebuild kit.
Major cam in it.
And then I have to go and put it all back together myself.
okay well i just got a phone call from my brother and he has spoken to the guy that did his torana and hes quoted 3500 if i get the motor myself
thats sounds abit cheap it was gunna cost me just 3500 too get my 5l rebuilt to stock standards
i paid $5300 for mine with big cam, headwork, race series pistons, chip.
Adzzaman Now Available In Surround Sound
i dont understand what it is your trying to find out man...you ask how much it is for a "race built v6" (what ever it is you mean by that)...but you already have a quote from a friend for $3.5k...
i dont know what it is you want to do in the 'build, but ill tell you straight up that for a good rebuild with decent parts and machine work it would cost more than $3.5k just for parts...and i dont see why this friend of your brothers would rip himself off.
acl race series higher compression rebuild kit is around 800-900
new reground cam is 650
flowing the heads and shaving the head face alone is around 500
new valves and springs 300
rocker arms 550
bearing kit between 100 and 500 depending on quality
hone and bore again 200-1000 depending on quality
thens there all the annoying shit like spark plugs, injectors, lubes, assembly, disassembly, intake manifold, throttle body, etc.
3500 is very cheap.
I got quoted by a shop $4000Originally Posted by chunderlicious
Deck block, hone it, and bored 40 thou.
Flowed and ported heads
New Cam
All the valve spring bits and pieces etc.
And then I have to put it all together.
I then need to source a new throttle body. Intake manifold will be altered around.
When I build it, I'm also going to be full blueprinting and balancign the engine.
Injectors/plugs I also have to buy on top of that price.
sell you mine for $2500
Vp v6 series two motor, bored and honed 40thou, ACL race series pistons and chrome molly rings, standard con rods, crack tested, check for bend and twist, fitted with ARP bolts, resized, pistons and con rod blanced, skimmed heads, 3 angle valve seats, k-line guides, new stem seals, slight port work, stock manifold , wade 992a cam, single row roll master timing chain, ACL big end and main bearings, new seals through out, new brass which plugs, done around 3000-4000km, chrips down shift from 40-50km witha stock auto diff and good rubber
