+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 29
Thread: vn v6 intake manifold/head difference between series one and series 2/vp/vr
    hakhawk's Avatar
    hakhawk is offline forum adjudicator hakhawk Grange hakhawk Grange hakhawk Grange
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Default vn v6 intake manifold/head difference between series one and series 2/vp/vr
    ok, for those that want to know the differences between series one and series 2 vn v6 (series 2 is also vp, vr) heads and intrake manifold, heres some pics. i dont feel liek listing every different thing, but the pics show most of them quite easily.
    just post if you have any queries, yme or someone else will give you an answer
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    im not sure if its just me but the S2 manifold looks like it has more rough cast marks inside.
    Dose anyone know what the round thing attached to the bottom of the S1 manifold it.
    I had a look at the one on my old manifold and it didn't seem to have a purpose
    Check out My SV8 One Tonner
    You can get a lot farther with a kind word and a gun than a kind word alone
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects..... Blown V6 Hatch W427 Blown V6 Hatch W427 Blown V6 Hatch W427
    VN Calais 5.0, UC Torana L67, WB Ute EFI 5.0
    Jun 2005
    Cowes, Phillip Island
    The round piece on the bottom of the series 1 manifold is below the positive crankcase ventilation (PCV) valve. It stops the oil from being splashed up the into the PCV valve. The PCV valve is just a one way breather and shouldnt have oil being splashed up through it.
    VP Executive R-spec
    Jan 2005
    The only real difference between them is that the series 2 has runners that are about 1 inch longer. It's worth a few KW and NM
    1991_Vn2nV's Avatar
    1991_Vn2nV is offline Donating Member 1991_Vn2nV GTS 1991_Vn2nV GTS
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    hakhawk's Avatar
    Jan 2005
    it can, just look at the pics. they will bolt up fine, just you will either have to use only the rocker cover pipe for pcv or.... you can with a little work, drill the holes in the head, just be real careful not to go too far.
    1991_Vn2nV's Avatar
    Mar 2006
    hakhawk's Avatar
    Jan 2005
    coolant passages are in same spots. but one on the s2 is blocked off, but this doesnt matter, as the coolant passages in the heads are the same.
    1991_Vn2nV's Avatar
    Mar 2006
    Ah ok fair enough. In the manual it says thats why the series 2 intake cant go on the series 1 engine, cause of revised coolant passages.
    hakhawk's Avatar
    Jan 2005
    well, they look the same to me. all the hosing is revised, so you'd have to change the hoses to suit. gaskets match up, as holden supposedly only sells the s2 gaskets now.
    VYII SV8 One tonner
    Apr 2004
    Central Coast, NSW
    Quote Originally Posted by greenfoam
    Why is the S1 VN suposed to be the torquiest engine if the runners arnt as long
    VP Executive R-spec
    Jan 2005
    It's got a bit more radical tune and a more serious camshaft (so the legend says), also the tube exhausts on the VN maybe a little better than the VP's cast ones. I'd say the VR executive with a retune is the fastest out of all three early models anyway
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by chevy_big_block_bro
    The series 2 has more torque, although only 1NM more.
    The series 1 engine has more torque down low though with 92% of max torque available from just 1200rpm through to 4000rpm. After 4000rpm though the torque drops off pretty quick, where as the VN S2 doesnt develop as much torque down low, but retains it later in the rev range.
    immortality's Avatar
    immortality is offline crappy ol' VN driver immortality W427 immortality W427 immortality W427
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    My understanding is that the S1 had a higher lift less duration than S2 which had less lift but longer duration which sound correct when the S1 had more torque early vs torque later in the rpm range. the high lift/less duration setup does have the down side of faster wear/tear in the valve train region unfortunatly. by fitting high ratio rockers to the S2 plus lifting the compression ratio slightly you should be able to get the same bottom end as the S1 with the top end benefits of the S2 engine
  15. #15
    simc is offline Supercharged V6 Gemini simc Executive
    Jul 2005
    Anyone know if the VP and VR heads the same? Was it just the higher pistons that knocked up the compression?
    Current Rides - The Daily: BA XR6 Turbo -The Scary One: TE/G Gemini Supercharged 3.8L V6
    The Cruiser: 1966 XR Fairmont V8 - On Two Wheels: Honda XR250R - The Wifeie: VZ Wagon
  16. #16
    VP Calais '93
    Mar 2006
    SA- NE BURBS
    Is there a thread sumwhere that talks about the possibility of fitting ecotec heads to an earlier model V6?
    cheers
    wtb: rockford fosgate sub rfp 3412
  17. #17
    hakhawk's Avatar
    Jan 2005
  18. #18
    cozer's Avatar
    cozer is offline Cozer cozer Executive
    vn v6
    Jul 2006
    Quote Originally Posted by hakhawk
    does anyone know if s2 fuel rail will fit on s1 or of a way to change the s1 pressure reg???
  19. #19
    hakhawk's Avatar
    Jan 2005
    fuel rails arent compatible, mounting positions are different. changing fuel reg, im not sure, but id assume you'd need a fitting made to connect to rail, then run a aftermarket inline fuel reg
  20. #20
    vq rat's Avatar
    vq rat is offline vq rat vq rat Berlina
    vn bt1 burnout weapon
    Mar 2006
    hamilton vic
    Does anyone make off the shelf fuel rails to suit v6s that you can run a aftermarket fuel reg ?????
  21. #21
    vz sv6
    Dec 2009
    i converted a vn s2 v6 intake over to my s1 engine i used the fuel rails off the s2 intake an throttle body etc i just had to run the temp sensor an sender wires to the front under the alt insted of having them run at the back. everything runs fine. i have a problem with my thermo fans tho they wnt kick in the wiring to the ecu is all ok and all fuses an sensors an relays are all fine but fan still wnt kick in any thoughts??????
  22. #22
    VN S1 V6 manual executive
    Mar 2010
    S2 v6s also have a plasic bellmouth inside the manifold take it out you will gain a bit of low end power from doing this ,series ones dont have them at all
  23. #23
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐ Super_Low 91 Executive
    R.I.P VN
    Sep 2008
    QLD
    What about mounting the series 2 intake backwards so that the throttle faces forwards? ( reverse mounted style ), could it be done without modifications?
    Feel the rush of boost
  24. #24
    hakhawk's Avatar
    Jan 2005
    Quote Originally Posted by shane_90 View Post
    you'd need to relocate the alternator and anything else that will get in the way, but it can be bolted up 180deg around
  25. #25
    R.I.P VN
    Sep 2008
    QLD
    so if i relocate the alternator an the other lil things in the way it will work fine. hmm,
+ Reply to Thread
  1. vx berlina series 1 and series 2 whats the difference
    By rgormley in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2010, 05:40 PM
  2. Whats the difference between a series 1 and a series 2 engine???
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-09-2006, 07:56 PM
  3. Put a Series 2 intake manifold on Series 1 engine?..
    By Hairy Eater in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2006, 08:23 PM
  4. difference series one and series 2 VR calais/commordore?
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2005, 09:09 AM
  5. How to tell the difference between a Series 1 and Series 2 VX Commodore
    By ForceX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-07-2005, 06:54 PM
