Results 1 to 8 of 8
Thread: Advice on which engine to rebuild please
    VR 94 Commodore
    Jul 2006
    Default Advice on which engine to rebuild please
    Hello all.
    Finally got my Eaton M90 and manifold to suit the Pre Ecotech V6.
    I will be rebuilding the engine for it and following similar specs to what the V6 Vengeance project contained but won't be spending all that money as is just for a very nice daily driver and some fun.
    The question I wanted to ask those of you with experiance in the specs of the pre ecotech V6s is : Would it be better to rebuild the spare Series 1 3.8l Buick or get a cheap Series 2 3.8l Buick and rebuild that ?
    What are the pros and cons and which should give a better result ?
    I really appreciate your advice and eagerly await your replies
    VC Twin Turbo, VN Turbo, VY Storm
    Oct 2006
    Wheni build a Motor for my VN i want a VR bottom end so i have the removeable Rear Main Seal. the VN/VP have the rope seal which is a bitch.
    Also if using new pistons get the 8.5:1 comp ones. some people say Vr is higher in comp.
    VR 94 Commodore
    Jul 2006
    Default VR heads diff to VN heads ?
    thanks for that. so use better comp pistons.
    Will VR Heads flow better / worse than series 1 heads ? Do they bolt straight onto block ?
    Cheers for your help
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    the s1 v6 uses a different crank and rear seal, different intake etc. the s2 is probably more common as it was carried over into the VP/VR etc. not sure on the heads or the CR ofthe later engines
    Body by Holden, Soul by Brock
    the Legend will live forever
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    from memory the compression of the vr engine is slightly higher, i think 9:1, as opposed to 8.5:1.
    i think your best bet is to just use a complete vr engine, i think the heads on these are also marginally better than previous s1 items.
    cruzncommo is offline Banned
    VP 5spd
    Nov 2006
    QLD
    VR 94 Commodore
    Jul 2006
    Default Many thanks
    Ok guys thanks for that. Will see if I can find a cheap S2 engine but if not sounds like s1 will be ok.
    Appreciate your help
    cheers
    Aug 2004
    get the series 2 vp engine from vn series two they all have the one piece rear main, and as for it being better i dont think it is, my old series one motor had done 195 000 km didnt leak a drop my new engine has done 12 000km its had 4 rear mains all leaked and is still leaking my mates vr commodore 165 000km leaks, mates vp commmodore 164 000 km small leak, u tell me which is better
  1. rebuild engine
    By bundyman in forum V8 Development and Modification
    Last Post: 27-02-2006, 09:31 PM
  2. Engine rebuild
    By G4orce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2005, 10:40 AM
  3. To rebuild or not to rebuild!? advice needed
    By Jason1987 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-08-2005, 08:36 PM
  4. V8 Rebuild and mod advice needed
    By Daters in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2005, 09:09 PM
  5. Vn V6 Engine Top-end Rebuild
    By jules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-01-2004, 08:20 AM
