Page 1 of 6 12345 ... LastLast
Results 1 to 25 of 137
Like Tree4Likes
Thread: VN Series 2 - VR Bellmouth
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Default VN Series 2 - VR Bellmouth
    Ok i'm going to post this as it is the cheapest mod and one that is asked about a fair bit.
    Ok this only applies to Series 2 VN's thru to the VR.
    Firstly the bellmouth was fitted to improve air distrabution to the rear cylinders providing an even air:fuel mixture for the whole engine, giving a smoother idle.
    So from what I just said there is a chance that the idle may not be as smooth as previously but hey, when are the Buick 6's ever smooth
    Now I'm not promossing any increase in power but, you will find you will have an increase in throttle response.
    I have included a picture to show the location of the bellmouth and will write up some step-by-step instructions on it's removal abit later.
    Cheers AirStrike (Dave)
    Selling FG G6E Turbo and buying a N/A Supra
    MoSkA's Avatar
    MoSkA is offline Steriotypical Wog
    1998 Subaru WRX
    Jan 2005
    It's said that if you get a CAI (Cold Air Intake) after taking out the bellmouth. The engine will idle pretty much normally.
    Without a CAI it is said the engine will idle rougher.
    I can vouch for the engine being rough without a CAI and Bellmouth.
    I don't use windscreen wipers, i just use the superior handling of the STI to dodge the rain drops.
    88 VN CALAIS 5.0
    Jan 2005
    Default Not Smooth ?
    Just a quick 1 .. every1 in here says that buick v6's arent "smooth".. LOL i disagree totaly, i have never driven a car with a smoother / more powerful & echanomical motor than a good ol commodore. Maybe you all need volvo's !! smooth as a baby's bum
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Ummm what are you comparing the smoothness of a Buick V6 to?? A Camira with no compression in to cylinders?? lol, nah she aint that bad but I had better....
    AirStrike
    soulyouth's Avatar
    soulyouth is offline Space Docker
    Sold for scrap :(
    May 2004
    Bossley Park
    Exclamation This Is A Great Mod, N Easy to Do
    This is a Step by Step removel Guide that I found in one of my old mags thought it might be handy
    Click here for Guide
    Attached Images Attached Images
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    i think his last ride must've been a kb ford laser running on 3 cylinders. on lpg, with bald tyres, blown driveshafts and cv joints, worn shockers, blocked up exhaust and some uncomfy indian taxi driver bead things over his drivers seat to call buick smooth!
    blowera1 is offline FranticTicToc2
    VY S Ute 3.8l M5
    Apr 2005
    Thumbs up
    are there any other negatives with removing the bellmouth???
    This Monster Lives
    VY S Ute 3.8l M5
    Apr 2005
    Thumbs up
    also the current issue of aussie brutes has a step by step guide for removing the bellmouth including photos
    This Monster Lives
    VZ 3.6 Police pack
    Mar 2005
    The Desert
    mmmm, might do that today, hang on...Shanghai ... will try with various intakes anyway (stock, cold, pod, direct, but already has ruff idle & runnin v8 throttle) will get back to you...
    any more testimonials...
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    it was fitted to improve idle quality & will not decrease power or throttle response, any improvements noticed may just be wishful thinking
    As it happens i was in Holden experimental at the time this was done so i have seen first hand the effect on the engine.
    Cheers Rob
    VZ Maloo 6spd
    Mar 2005
    Quote Originally Posted by matt2950
    This had me concerned until I realised you are obviously driving a 6 cylinder VL...you are aren't you...???
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    what do you mean it won't increase / decrease power, after removing it. It's a restriction on the air flow. If you cover half your throttle body with gaffer tape are you saying it won't make a difference.... Of course it will.
    fair enough the removal of it may cause the rear two cylinders to lean out a little because the length of the bell mouth puts the incoming air into the centre of the manifold distributing it evenly. hence better idle, but who drives a car on idle???
    take the damn thing out, common sense says that car manufacturers create engines to be fuel economic and drivability. If your after power remove it thats all their is to it
    VT
    Apr 2005
    QLD
    Quote Originally Posted by sp001in
    i agree...although maybe a tune might be in order after removal....i know a tune just for that might seem silly, but if thats all you're going to do......
    rattattack1313 Guest
    Cool
    was chatting to some mates the other day...they said , if Im gunna take the belmouth out, I shoulld then modify it like in the rather crude drawing I just did.........that way , the air is getting to the middle of the valley, but with less restriction......
  15. #15
    Cool
    wellll got industious enuff to remove the throttle body etc.......all three gaskets were R.S. .........so I made 2 new ones, and gasket-goo-glued the other on....and hacked the daylights outa the Belmouth ( see pic.)...just went to get the Minister of War & Finances....and wow !!!!!!!!!!!!!!! what a difference !! !!!!!!! heaps better in the gear changes......
  16. #16
    soulyouth's Avatar
    Sold for scrap :(
    May 2004
    Bossley Park
    Question hmmmm
    I see you cut a fairly big chunk out of the back of that bellmouth but failed to widen the opening of it. You may have opened the back end up, but the air is still getting bottled up at the mouth of the bellmouth, maybe you should have also removed some of the plastic from the opening too.
    Just a thought...................I could be wrong through, the throttle response after taking the bellmouth out completely and having a pod filter right on the Throttle body is insane, you should hear this car suck, with stock pipes it sounds like its got a 2" system
  17. #17
    Cool
    yea mate......my tankslapper mates said it was best to do it that way......it still resrticts the air a little as the air goes through the bellmouth, but it gets released earlier inside the valley, is how they explained it to me.......i have noticed a helll of a difference...on a hill that she normally takes in 3rd, and kicks back to 2nd ,about 40 mtr from the top, stays in 3rd now all the way to the top ........every gear change is smoother........
  18. #18
    Aug 2005
    Wouldn't removing something that evenly distributes air/fuel lead to non-uniform wear and less power? To my way of thinking, if not every cylinder is getting the same amount of mixture, they can't be working as efficiently as they could be, and if some are getting more/less, then they are going to wear differently. Given that, why would you remove the thing?
  19. #19
    Cool
    Why would anybody modify any part ???? To make the car go better, of course......... :rat:
  20. #20
    bergles Guest
    i just gave ripping it out a go, and i also cleaned out my throttle body, but when i reassembled it, my fuel rail on the left side (looking from the front) is making a high pitched almost mechanical like noise. no engine light though. has anyone got any answers to this. at first i forgot to put a vacuum hose on the back of the throttle body then started it... heard the whoosh sound then reconnected the hose, now it is just my fuel rail making noise
  21. #21
    s0sage's Avatar
    Mar 2005
    it sounds kinda like you've done some damage to your throttle body gasket in the process of pulling it off... either that or its not sitting in 100% straight.
    the tiniest bit of escaping air will give you that wooshing sound as the motor sucks air through it
    pull it down and have a look at the gasket and make sure its not ripped. if its all ok, just put it together SHIT CAREFULLY.... this is going to affect your fuel economy a bit if its not sorted out as the air/fuel mix will be wrong
  22. #22
    bergles Guest
    nah the gaskets are fine. everything is lined up all good. the sound isnt a whooshing its more like a mechanical types sound.....eg. a QUIET engraver or router. it idles fine and everything, got a tiny bit meatier sound in the exhaust, just cant figure out why my fuel rail is making noise now even though i didnt touch it. im gonna try and see if the computer will let me know what the deal is.
  23. #23
    bergles Guest
    well the computer says A ok. stripped it down and put it back together again and now its gone....bloody car. a nice mod that works a little. has definately given it a slightly meatier sound in my car (i have 3in from diff back) but i need to do the whole exhaust cause now i got a sub and good speakers and i cant hear my car enough. next will be manual conversion and decent L.S.D. i want a commodore that will drift like a champ.
  24. #24
    VX V6 /VR V6
    Sep 2005
    I have removed bellmouth on my VR V6 did couple of quick power runs (as I work in a dyno tuning workshop)and no extra power anywhere in the rev range so naturaly I put it back where it came from
  25. #25
    ford
    May 2005
    in a ford
    rs 2000 thanx if theres no gains i wont bother taking it off
  1. Removing bellmouth
    By Trewman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-07-2009, 09:15 AM
  2. Bellmouth
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-11-2006, 11:35 AM
  3. bellmouth
    By executive_power in forum General
    Last Post: 31-07-2006, 09:32 PM
  4. Bellmouth
    By bush_basha in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 07:47 PM
  5. Bellmouth question
    By rodge26 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2005, 05:06 PM
