Results 1 to 8 of 8
Thread: Engine Rebuild
    2007 VE SSV Manual
    Apr 2007
    Default Engine Rebuild
    Hi, all
    I guess this has been asked many times but i thought it can't hurt to post.
    I was just wondering how much it would cost to do a full engine rebuild to set up a Series 1 3.8L for a supercharger/turbo running 15-20psi of boost.
    There is no budget but I want atleast 300kW atw and a strong engine that won't need a rebuild for at least 200,000km's. It is stock standard at the moment.
    Also if other things should be done along with this then let me know what and how much they cost.
    I can probably do most of the work myself so I just need to know prices for parts.
    If this is a stupid idea then please give me other ideas as well , I really want some more power out of my VN . Thanks
    vn calais
    Dec 2006
    check out the come racing site. they do a complete stroked engine to suit boost for bout 10k. also check out prostroke engines. but depending what parts you use roughly 6 to 10k.
    VN Commodore
    Feb 2006
    i think ya should work out what you really want first. do you want a turbo or supercharger. do you want it streetable or for drags??
    MaN|aC's Avatar
    MaN|aC is offline Donating Member
    VT 4.2 S/C
    Apr 2006
    Quote Originally Posted by Wasa View Post
    There is no budget
    thats easy then, 10 grand on a stroker from COME (forced induction engine) and put a supercharger on it.
    http://www.comeracing.com/index.shtml read first section on the blown stroker for the ecotec
    im doing this atm with my stroker
    208rwkw 13.5 @ 102MPH
    STROKED AND BLOWN
    2007 VE SSV Manual
    Apr 2007
    I want it streetable, and what about stripping the 3800 and setting it up for a turbo?
    2007 VE SSV Manual
    Apr 2007
    Ok, so after talking to a few people i've changed my mind.
    I want it supercharged.. and running on 7-11psi. I want to replace the internals with stronger bits (if need be?) and get a hot cam and a decent but not overly loud exhuast. And a CAI pod filter setup. Any estimates on how much the internals will cost to replace? if they even need to be at that boost?
    I'm guessing that the other gear is around about 5-6k (correct me if im wrong)
    VS Commodore V6
    Feb 2007
    Hi Wazza
    I have recently rebuilt a VS V6 Ecotec Commodore as an on-line project.
    The engine was kept naturally aspirated and I achieved an actual gain of 31 kw as compared to the standard engine.
    My web site is: www.mystreetcar.com.au
    If you get a moment, check it out...!!!
    I am not to sure if this is the sort of info you are looking for however, there may be some ideas and info that may help you with your upgrade plans.
    Good luck
    Peter
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    Have a look at the forum sponsors. We should be supporting the people that support us.
  1. VS engine rebuild
    By PSIHTR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2007, 01:51 PM
  2. Engine Rebuild
    By Wasa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2007, 11:22 AM
  3. Engine rebuild?
    By adamtuba in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2006, 07:06 PM
  4. Vs engine rebuild
    By sleepyvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-03-2006, 06:25 PM
  5. Vn V6 Engine Top-end Rebuild
    By jules in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-01-2004, 07:20 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98
