gday everyone, i dont actually own a commodore but i am currently researching about commodore v6's for my hilux 4x4. Im just looking for a few suggestions, like whether i should go an ecotec or the vn or vp 3.8, im gonna keep it naturally aspirated but im after a fair bit of horsepower. i have contacts where i can get the motor for a carton but it would need a rebuild, i was thinking of running a high compression set up, like flat top pistons mild cam port and polish, i can pretty much do the rebuild myself as i have some experience in rebuilding engines (cough gemini cough) but im just after a rough price for parts. and was also looking for some testemonials from people running a similar set up in there street commodores. how much would it cost for a full rebuild kit back to standard to?
Your probly looking at about a grand for a rebuild kit. If you want more power you can always run a stroker kit, there about 2.5k
How to be a good Australian Citizen: Drive a Camry, Become another number in the system, Dob in all other numbers for un-numberlike behavior (no matter how slight), Base all your opinions solely on the information provided by T.T. and A.C.A., Believe everything our gracious Government Tells you to.
what sort of horse power would i be looking at with a stroker kit, ported and polished head and a mild cam?
this is what its going in by the way
Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
thats what im after, but i dont know whether i wanna spend that much, i just got back from a 4x4 comp at jimna and i saw alot of hilux's and surfs getting around there with commodore v6's or fuel injected 308's and theres alot coming from no where running lexus quad cam v8's!
get a standard rebuild shave the heads put a mild cam in it headers, eshuast v8 tb, clean the manifold up abit while its apart, should go okay and have a nice idle
Sir Cruize, wouldnt he be saving a coupla grand by getting the strocker kit and not the short block already built tho?
Best bet would probly be to buy a low km wreck coz thats gonna have all the electronic gizmos that the ecotec or even the buick motor needs to run.
yeah, that depends...most likely no. unless he can do all the labour and machining, or can get machining done cheap (like a mate or something) the short block is actually pretty good value for $4500 outright, delivered (as opposed to i think its $2500 just for the kit, which has crank, rods and pistons).
you get a choice of cam to go with it and then all you need is some heads and a tune.
