Quote:
Originally Posted by needwork2-4fillhabbit
Ok. Have a look at darons pics of his setup on page 7 in this thread, whats the difference between the ata cooling affecting it so much?
The thing you guys have to realise with darons is he has a MAF sensor. Daron you make 233kw with the setup on page 7? no cooling? how much boost are you running?
Another thing TB should aways be mounted on the inlet side of compressor. so you dont end up with a build up of pressure. It's better to have sucking against a closed throttle then psuhing against a closed one.
