Page 8 of 10 FirstFirst ... 45678910 LastLast
Results 176 to 200 of 227
Like Tree2Likes
Thread: diff, all you need to know
  1. #176
    Zeussy's Avatar
    Zeussy is offline SSM11K
    VY Acclaim S2, VH SLE
    Dec 2008
    Central Coast
    Hey immortality,
    If I've got this right...
    I am going to be starting a conversion soon, VP into VH, pretty much all the engine/running gear out of the VP, into my old VH... Or had the plans too?
    Is the only difference between the diff's the width - as in the track will be 52mm wider = so the wheel will stick out 26mm further each side?? yeah?!
    Is there an advantage to put the VP diff in? I was going to just shorten the tailshaft and swap it all.
    Or just keep the VH diff? The VH diff is for a trimatic 6, if I used that would the ratio be wrong for the VP aswell?
    And do you know if the brakes are the same on the rears, plan to put all the VP booster, calipers etc in with the conversion.
    Basically have a complete VP, and going to lift the body/shell off and swap it with a VH...
    "WHY" I hear people asking, because the Mrs wants too... lmao,
  2. #177
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by zeussy View Post
    Hey immortality,
    firstly, lets look at the diff. the VH SL/E could be optioned with the large salisbury which should be up to the task of a stock V6. not sure what the ratio was. even if it is the smaller sals diff it should be ok. just attach the rear half of the VH drive shaft to the front half of VP drive shaft. yes the BW78 diff from the VP is 52mm wider but it will bolt straight in otherwise. if you do want to go down this path it may be better to source a VL diff as it would be a better fit.
    if the VH has a disk brake rear it is basically the same. booster and master cylinder are also the same 15/16" size. basically swap the entire K frame/ front suspension including disks and calipers into the VH.
    a V6 will liven up a VH nicely, the same engine KW output as the stock V8
    Body by Holden, Soul by Brock
    the Legend will live forever
  3. #178
    Zeussy's Avatar
    Dec 2008
    Central Coast
    Quote Originally Posted by immortality View Post
    Legend! haha, yeah for sure, a mate had a 5 speed manual, (V6, VH) and it was quite the little weapon. For a measely $250 its by far the cheapest option so far...! Our one will be auto though, still tough enough for a chick! lol.
    Yeah, my SLE came with the 4 wheel disc option, so I'll have some spares? Is the handbrake cable the same as well?
    How do you tell the difference between the small and large salisbury? I have it just sitting around the side - the SLE has an empty 9 inch sitting under her - no centre just axles and housing. So either way i'll have to put one of the diff's under there?
    The tailshaft's rear uni is about 65mm, with roughly 25(ish)mm end caps? And the Diff has the rear plate on it about 26cm wide - not the centre, just the cover plate. Are there any numbers stamped on them?
    I'm pretty sure the ratio is 2.78 or something along the lines of? Somebody told me a while ago 'it should be' (when I put the aussie 4sp in it)
    Even though I'm a Mechanic (Plant/Earthmoving) I've never really known much about the old gurls!
    Cheers mate,
  4. #179
    Apr 2006
    Auckland NZ
    Cheers mate,
    well, the 9" diff is worth a bit. could pay for the a lot of the conversion bits
    the large sals diff has a egg shaped cover on the back of the diff. the small sals was round. also the large sals uses a 10bolt center. if you pull the diff cover off the diff ratio will be stamped somewhere around the circumference of the crown wheel.
    there is a thread stickied at the top of the VB-VK section dedicated to doing V6 conversions. should have all the info you might need
  5. #180
    Zeussy's Avatar
    Dec 2008
    Central Coast
    It could pretty much pay for it, OR it could pay for some paint for my VY!!! lmao... Finally!
    Well, the cover looks to be closer to round, than egg shaped, so thats a bummer. Might try find a decent/cheap VL diff, does it have to be V8? And what ratio would be preferable, in your opinion?
    Theres still the option of the VP diff as a fall back plan, might even try that first, then if the tyres stick out too much worry about it then?
    In the 'VB/VK V6 Conversions' thread they say something along the lines that the VR/VS is where the models get wider, and the front of a VN/VP will be the same width as the VB/VK? Is the rear wider than the front? lol.
    Hmm, something to ponder anyway?!!
    Over the last few days I have been doing a bit of reading! Mainly the V6 conversion threads, then deviating onto other topics, then luckily came accross this great thread - Good write up btw! lots of info in it. LOL.
    I swear this website is full of potentially verrry valuable information, High five for all involved!!
  6. #181
    Apr 2006
    Auckland NZ
    you can use any VL diff, although all the V8 ones were 4spider centers using 28spline axles and had the 3.08 ratio.
    the 6cyl VL had 3.45 gears but only used a 2 spider 25 spline center. you could upgrade to a 4 spider center from any other BW78 diff but the issue will be getting axles that are the correct length. you could use a VLT diff but people seem to think these are gold plated and charge accordingly.
    yes, the fronts of the VN/VP are the same. the width of the diff did change. thats why a VN with stock 14 or 15 inch wheels looks puss because the body looks way to wide. you could try the VN diff, as long as you don't chuck 17x8" rims on it, it might not be to bad.
    no point keeping all the info to ones self. might as well share it. i've learned plenty from people on this site so it's only proper to return the favour
  7. #182
    Zeussy's Avatar
    Dec 2008
    Central Coast
    Haha, yeah I've noticed the VN's wheelbase - width looks way too narrow for the cars body..!
    Probly eventually will be getting rims, its just sitting on the SLE rims, they're polished up shiney! I had the 20's on it before I took it off the road.
    So probly should do it right the first time then. (not to put 20's back on it, but most likely something a bit more comfortable)
    So preferably a VL V8 diff, and if we can't get a complete one, (which we should be able to, but just so I understand correctly) any VL diff, with the VP Centre, (the one in the doner car) and VL V8 axles - is that the right combo? lol,
    Sorry for all the questions, I really appreciate all the help.
    I always try to help others where I can too. I have the same attitude, I've learnt heaps from here, so I'll try to help someone back..
    What ever else I end up learning from all this I will be sharing with the rest of the forum! Either in the 'VB/VK V6 Conversion' thread or this one, or both lol, and my ride thread.
  8. #183
    Apr 2006
    Auckland NZ
    a complete VL V8 diff would be the go as it's already a 4 spider 28spline unit. if you can't find one of those a a 6cyl VL diff with your VP center and you would need to find some 28spline shafts to suit
    check this thread for a pic of a large salisbury diff. your top mounts will be different though
  9. #184
    nissan bluebird TRX
    Mar 2010
    Hey I have Datsun 1600 engine that I'm putting into a bluebird TRX, and I'm after an LSD for a Banjo differential, could someone recommend a fairly cheap way of doing this?
  10. #185
    VS BT1 commodore 3.8
    Oct 2007
    I have a vs v6 LSD 3.08:1 ..would the centre fit into a vl diff housing using vl axels ?
  11. #186
    Jan 2008
    NSW
    If i put a VX SS diff into a vt s1 v6 do i have to change CV's and hubs? to vx ss ones??
  12. #187
    A bicycle
    Aug 2009
    Gippsland, Victoria
    just a quick question. is the only 'diff'erence (lol) between the v6 and v8 diffs in a vs ute the shot peened gears, or are the axles and other bits different?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
  13. #188
    Apr 2006
    Auckland NZ
    Quote Originally Posted by old mate View Post
    yep. just shot peened gears. unless it has the "performance diff" tag. which should mean it's optioned with the LSD diff
  14. #189
    A bicycle
    Aug 2009
    Gippsland, Victoria
    i've got the high peformance tag but its a single spinner. maybe all the utes had shot peened gears??
  15. #190
    5 speed VR's Avatar
    5 speed VR is offline Green Machine
    Vr V6 Exc 5 spd
    Apr 2006
    Sunny Coast QLD
    If there is a tag saying "use LSD oil" its an LSD, but if its got "use high performance oil" its just a V8 diff
    When i grow up... i want to be young again
  16. #191
    VP Calais '93
    Mar 2006
    SA- NE BURBS
    Diff upgrades
    However it is possible to fit the entire IRS setup from a late model commodore (VTs2,VX,VY) into a earlier model IRS comodore but you also need to use the drive shafts and hubs from the donor car (STEALTHY has done this in his VP international)
    if there is anyhting i've missed or you believe is incorrect please add it beneath and i'll update this post as info becomes available
    I reckon you will find that the early model and late model IRS diffs have different flanges where they bolt to the tail-shaft- so they are not a straight swap. Late model cradle wont bolt up to early models. Trailing arms are interchangeable- keep in mind hubs differ depending on model also track link adjustment (or whatever its called) wasn't introduced to VX Series II. Sorry if this has all been discussed earlier.
    wtb: rockford fosgate sub rfp 3412
  17. #192
    VK V6
    Mar 2010
    NZ
    Some more info on widths of VK 1/2 and VL Borg Warner housings:
    vl axles into vk diff
    According to my measurements the two are identical in width, but the VK 1/2 centre is somewhere in the region of 30mm further offset to the right when compared to VL. This means the short and long axles are 30mm longer and shorter respectively.
    Not sure where the quoted 12mm width difference figure came from; approximately 6mm could be accounted for in the difference between drum and disk brakes. It has also been suggested that the Salisbury could be slightly different, I don't have any here to measure to check this.
  18. #193
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
  19. #194
    VN Series II Vacationer
    Mar 2009
    Ipswich, Qld
    Just want to see if I got this right.
    I own a VN V6 series II with the standard BW single spinner diff - ratio is 3.08
    So this diff has 4 pinions carriers with 28 spline axles.
    Can this diff be modified to LSD setup, as this is a stronger diff all round.
    I'm told my current diff will not handle my intended mods of a heavily modified blown V6 with 6 speed manual from a later model commy.
    As I am in Brisbane, is there a reputable person/workshop who can modify my diff if needed.
    Thanks for your time
  20. #195
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Quote Originally Posted by mrtdk59 View Post
    For the First Part the answer is yes.
    Secondly the Borgwarner78 series diff is exactly the same as the lsd version besides the the centre Being an lsd instead of an open wheel.
    So you just need a LSD center put in and away you go. A Rebuilt LSD should handle a blown V6 easy. There are few other options to look at including spools and lokka diffs. Personally id stick with LSD.
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  21. #196
    Apr 2006
    Auckland NZ
    there is a guy on SC who uses a shimmed BW 78 LSD diff in a 9 second VL V8 turbo. nuff said about how strong they are when they are built properly
  22. #197
    Drawnnite's Avatar
    Drawnnite is offline Obviously Unsensible
    2000 Vs Ute
    Sep 2010
    so ive asked this elsewhere but think it would be more related to this thread.
    ok so i have a VN V8 LSD all recoed etc.
    i have read the VN Wagon diff is the same as the VS ute.
    however it regards the Bump Stops.
    would any modifications have to be made so it will fit or would it not matter?
    for eg is there any plates different or none at all?
    Thanks in advance
    EDIT:
    i think i answered my own question by looking properly, but i may be wrong, any info would be awesome
    how about we make the pedals out of sticky rubber and the shoes with steel spikes. at least my shins would like that
    Quote Originally Posted by Jonesy484 View Post
    yeah i wondered the same thing when i was 4 when i grabbed the chrome exhaust of my dads rx7
    Quote Originally Posted by DM 55 WA View Post
    did you think it was a milo tin?
  23. #198
    VT 50th anniversary 3.8l
    Feb 2012
    N.S.W
    wondering if its worth swapping my stock vt diff ratio's for the r31 4.11. my vt is just a daily but looking for more accelleration out of the gears more then speed. being that i think the v6 ecotech in the vt is to laggy in 2nd and 3rd. all opinions appreciated.
    ~Sophie
    Chev badge on a Holden? thats un-Australian.
  24. #199
    Drawnnite's Avatar
    2000 Vs Ute
    Sep 2010
    Quote Originally Posted by Sophie92 View Post
    ~Sophie
    4.11s are pretty high for a daily.
    if you dont drive it much for work then maybe.
    otherwise have you thought about 3.45's or 3.7's
    just so you dont completely kill the fuel economy =P
  25. #200
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    first of all Sophie you have to have a squiz under your car and check which diff is in it. There will be a tag on the driver size of the diff with the diff ratio printed on it.
    If you have 3.07 then you will need to find diff gears from a later model commodore
    If you have 3.08 then you can use gears from a skyline.
    What ratio to choose is personal preference really. Horses for courses if you wish... A car that is purely city driven= Go skyline 3.89's (3.91's if you have the 3.07 diff). For a car that gets driven over 80km/h regularly i'd lean more toward 3.45 (3.46 if you have the 3.07 diff)
    If i didnt have to tow cars on the highway with my daily then i'd go 3.91's in a heart beat
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  1. V8 Diff vs 6cyl Diff
    By RSO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 09:45 PM
  2. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  3. Swap VZ diff for VE diff?
    By georgehifi in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-03-2008, 06:31 PM
  4. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
  5. What Diff Is This??
    By vasrox in forum General
    Last Post: 05-10-2007, 11:37 PM
