Seeing as many of these questions get asked multiple times I thought I’d put this together for future reference.
history
The Borg-Warner diff was first fitted to later model VK’s, it had a 2spider center with 25 spline axles. On the VL’s they fitted 4 spider LSD centers and 28 spline axles for the VLT (turbo 6 cyl) with 3.45 ratio and V8 models with 3.08 ratio. From VN to VS and VT series 1 all BW 78 diffs had 4 spider centers with 28 spline axles, the standard ratio is 3.08:1 for all models, the V8 models had shot peened gears (crown wheel and pinion).
In the VP range Holden first introduced the Independent Rear Suspension (IRS). It is not possible to change a commodore fitted with semi trailing diff to IRS as the entire rear section of the floor pan is different, different mounts etc. Limited Slip Diffs (LSD) were fitted as standard equipment on SS models and optional on all other models.
also note that although sedans, wagons and utes all use the same borgwarner diffs the wagons and utes use different mounting points for the shocks and panhard rod so diffs from wagons and utes are not usable in sedans, all the gears and centers are still interchangable
Diff gears (crown wheel and pinion) are interchangeable between all BW 78 diffs including all IRS diffs. You can also fit a LSD center to any BW78 with open center, it’s a straight swap, just fit your original crown wheel to the new LSD center (unless changing ratio at the same time). IRS LSD centers are interchangeable with semi trailing diffs, however it has been suggested that for later model IRS commodores were fitted with a different offset centers and these would not be interchangeable with earlier models, however I have never seen one and I’m not sure about this.
Borg Warner has has a few different names over the years, the are currently owned by Dana ( a rather large US company that builds very tough diffs used in many US truck applications) and were also know as BTR at some stage
Diff ratio's
For those interested in other diff ratios for the BW78, the Nissan R31 Skyline and Pintara also used the BW78, these were fitted with 3.73 (manual and very rare) and 3.89 and 4.11:1 other ratio's also available are 3.27 (VP GTS). ford also used the BW78, i'm certain that the XD and XF falcons had the BW78 but not certain what ratio's were used. i've heard 3.23:1
Note of interest.
The VN GRP A commodores were fitted with diffs from the VLT with 3.45:1. They used these diffs because they are slightly narrower so that they could use wider wheels (different offset) under the rear of the car.
VT series 2 onwards they fitted the BW80 diff, which has a larger crown wheel and pinion, and also different ratios. Parts from these are not interchangeable with the earlier BW78.
What this means to you is that the mounting points for the diff from the first VB commodore sedan all the way to the VS sedan(not including IRS of course) are the same, so it's possible to fit any BW78 diff into a early girl commodore. however keep in mind that the VN-VS diff is wider (40mm) then the VL which is wider (12mm) then the VB-VK diffs. also note that the BW78 uses flange arrrangement to bolt the driveshaft to the diff were as the salisbury diff the rear universal on the driveshaft bolts directly onto the diff joke using 'U' bolts. to fit the borgwarner to a early girl commodore you will need to use the rear half of a driveshaft used with a borgwarner diff
Diff upgrades
However it is possible to fit the entire IRS setup from a late model commodore (VTs2,VX,VY) into a earlier model IRS comodore but you also need to use the drive shafts and hubs from the donor car (STEALTHY has done this in his VP international)
The Holden LSD is fairly average as fitted by Holden and have a tendency to single spin when abused. it is possible to have these diffs tightened where the clearances are reduced and fitted with better springs. this is a good idea to have done if fitting a used LSD as it's probably seen better days before you get hold of it. approx $300
Another option is to get a KAAZ center fitted, these are about the best LSD available but expect to pay for it. you won't see much change out of $2k
it is also possible to fit mini-spools in these diffs. mini spools lock both axles together so that both rear wheels always turn at the same speed. these are great for drag racing and doing skids. to fit a minispool you need to have a open center as they do not fit inside LSD centers. minispool $80-200 (supply only)
the next option is to fit a full spool. these fit in place of your standard center and your crownwheel bolts straight to it. these are stronger then minispools but would be considered overkill for even a decent street engine
if you are after a slightly different look under the rear of your car you can use the aluminium diff cover from a XD/XF falcon. you will need to remove the stud used for the watts linkage, other then that it's a straight bolt on option (you will require slightly longer bolts) and will need to slightly modify the bracket that holds the brake line under the 2 bolts on the side of the cover. these aloy covers can be highly polished and have the added advantage that alloy dissapates heat faster then steel thus helping to cool the oil in the diff faster (my diff guy recommends these are fitted to all diffs with higher ratio's as they produce more heat) a picture of one of these covers can be found in my ride (link at bottom of post) post 15 (page 1)
overview
VB-VK small and large salisbury diffs (large for 308 only and optional on other models), 2 spider center, optional LSD
VK 1/2 BW 78, 2-spider center with 25 spline axles, 3.23:1 ratio (6 cyl only, V8 continued with large salisbury)
VL BW 78, 2-spider open center 25 spline axles, 3.45:1 ratio (6 cyl), BW 78, 4-spider LSD center 28 spline axles, 3.45:1 ratio (6 cyl turbo), BW 78, 4-spider open center, 28 spline axles, 3.08:1 ratio (8 cyl)
VN-VS BW 78, 4-spider center, 28spline axles, 3.08:1 open and LSD, V8 have shot peened gears. VP onward Holden introduced the IRS as standard equipment on Calais and optional on other models
VT s1 BW 78, 4-spider center, 28spline axles, 3.08:1 open and LSD (same as VN-VS)
VT s2 BW 80, 3.07:1 (auto) 3.46:1 (manual)
VK borgwarner same width as salisbury diffs
VL Borgwarner 12mm wider then VK
VN-VS borgwarner 40mm wider then VL (52mm wider then VK)
once you have fitted new diff gears your speedo is going to be reading incorrectly. the simple solution to this problem is to fit a Jaycar speedo corrector kit, this How-to http://forums.justcommodores.com.au/...kit-vn-vp.html should cover all the information you need to correct this problem.
if your keen on getting your hands dirty and want to source a set of diff gears then read How to: Source your own diff gears and remove them yourself written by Wagon wheel
if there is anyhting i've missed or you believe is incorrect please add it beneath and i'll update this post as info becomes available
Body by Holden, Soul by Brock
the Legend will live forever
Awesome post![]()
Rated 5 stars, rep left, and voted for sticky. Excellent thread.
The 1972 HQ Kingswood
cheers guysas i find more i'll update the original post and try to get all the info in one place. one thought, maybe a mod can change the title to "Diffs FAQ"
Agreed, excellent post. Vote for sticky.
Great idea, also maybe add what centres out of other vehicles can be fit into Holden diffs? just a thought?
Would this be better suited to another section?
So that everyone can see it.
Originally Posted by davway
it possibly would, what would you suggest as it covers more then one section. VN/VP or VR/VS. it's also relevant to the modding V6 section and modding V8's as well. i honestly believe having a dedicated "transmission/driveline/differential" subsection would be best solution
sorry if this sounds stupid..but does this mean that i can swap the diffs between my vt ss s1 and vs stato?
Yes, i'm using an 03 GTO (same as VY) diff in my VP
how much moding would it take to get a vl diff under a vp?
VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
- Lou Holtz
Found my reply helpfull? Share the love and click the star down the bottom
Why would you want a VL diff? VP diffs are better. If anything, you'd get a newer diff, not an older one.
non, it's a straight swap. the VN grp A had the VL diff as it has a narrower track. all commodore sedans from VB onwards that had the semi-trailing arm setup have the same suspension mounting points so they are all interchangable. unfortunatly the wagons and utes are slightly different and aren't a straight swap.
would u guys reccomend 3.7s 3.9s or 4.11 in a auto vt ????????? still do alot of highway drving so dont wan it revin over 3 i guess on the highway
If it has 3.08 (or whatever the stock ratio is for VT) then you'll notice a difference with 3.73s.
I have them in my car (using a VY diff, so the same as yours) and its a good middle gear, keeps decent economy, and still has some pick up. DON'T get 4.11s, you'll lose too much top end.
Firstly i think this thread rocks but it's a pitty it's stuck in this section as this info will not be used to it's full potential as other users will not know about it. As you said there should be a driveline section to put it into.
I want to know if i can put a complete bolt out diff (cradle/frame, arms, diff centre, shafts, hand brake cable) from a VT SI up to a VY SII sedan and bolt it straight into my VS SIII Caprice. I have a Tungsten 98 VS Caprice Super and have just fitted brand new 18in WM Caprice alloys and tyres. I have a full set of genuine HSV brakes front and rear from a VX that i want to fit but apparently there are issues with the hand brake if i want them to go on my VS so i figured if i use a complete sedan diff from a VT SI upto VY SII this will get me out of trouble but i don't know if this is going to work. I am in the process of slightly lowering the car but before i do this i want to find this out so i can get the job done all at the same time.
If the diff from a later model bolts straight in will my tail shaft bolt straight up to the diff and will i need a later model hand brake cable. If it needs a later model hand brake cable will it need to be modified anywhere on the mounts on the underbody floor or modified at the hand brake lever.
Obviously the later the model diff i get will be better than an earlier one but will a later model diff say from VX SII onwards be the way to go as i have been told that the VX SII has adjustable sections for toe in and camber etc. Is there any extra benifits of fitting a VY SI or SII over a VX SII.![]()
Or, you could bolt up a Nissan IRS Setup...
Index of the Nismodore Build History
JetSpin Racing Team Mantre:
"F**k safety, I'm in a hurry"
i think your best bet is to have a look under a later model VT/VX/VY and see how the handbrake assembly is setup/works etc. as for the brake conversion, it's the actual hubs that would need changing to suit the later model brakes. unfortunatly i can't give a answer on that one as i'm not familiar with the differences in the hubs.
the best person to speak to would be STEALTHY as he has the later model diff in his VP so would most likely know everything that was swapped to make it work including any mods to his hubs/brakes
I have had a look at the arm setup on my VS and thought that a hub change over should do the job but then i was told it is an expensive process due to the hub needing to be pressed out and with certainty the bearing will be damaged and need replacing. So my answer to this would be to get hold of a pair of VT control arms with the hub already fitted and replace them with my VS control arms but will the VT control arms bolt straight up to the VS cradle/frame??
I would prefer to change the whole diff to a later model as i could put in an LSD from an SS or HSV Clubby and such but which ever way works would be better than nothing as long as the brakes can be fitted safely.
honestly mate, if you have good access to parts, get one from each and put em side by side and see if it will fit. i know the diff will definitly fit. it's the control arm/hub asembly thats the the problem in regards to fitting the later model brakes. as for the LSD, it's the same design as the BW78 so there is no advantage there really. what ever you find out, post it here and i'll update the original thread with what you find out to make it easier for the next bloke (if you don't mind that is)
Does anyone know about 7.5" and 8" BW80's, I just found out there are different sizes, trying to change the gears in mine and its getting complicated
Apparently the V8 use's 8" gears and center and the V6 use's a 7.5" centre and there not compatible, makes buying a set of gears difficult, also it appears that VZ V6 cant be mini spooled
Hopfully someone here can shed some light on all this![]()
