You won't know if you will be able to put standard sized pistons back in untill the motor is apart.....You need to see what sort of lip is at the top of the bores, if it's not too bad you might just get away with a hone and wack a new set of pistons & rings in and away you go. If it's pretty bad, then it's rebore time! If it's done a few K's, chances are it will need a rebore and a set of eversize pistons & rings....If you are only building a N/A engine then see if you can get hold of a set of L67 rods, they will be plenty strong enough.
