Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Modification and Development > V6 Development And Modification
V6 Development And Modification All your V6 Development and Modification Questions answered here
Reply
LinkBack Thread Tools Display Modes
  #1
Old 18-06-2008, 03:46 PM
Ride: VL Calais Series II
Trade Rating: (0)
Panama Executive
Default balancing shaft.
does removing the balancing shaft make the ecotec idle lumpier?
has anyone done this on an L67? howd it go?
__________________
Tell Them I'm "Too F**king Busy." Or Vice Versa.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 18-06-2008, 03:58 PM
vn calais manual's Avatar
Ride: vn calais, vs clubsport #137
Trade Rating: (0)
vn calais manual Executive
lumpier?. u get a bit more vibration through the revv range yes.
why.
  #3
Old 19-06-2008, 04:33 PM
Trade Rating: (0)
Panama Executive
want a lumpier idle and accel but not sure if its possible.
plus ive heard removing it makes for better response?
__________________
  #4
Old 19-06-2008, 08:37 PM
sircruisealotVS's Avatar
Ride: VS Equipe series ll
Trade Rating: (0)
sircruisealotVS MonarosircruisealotVS Monaro
lumpy idle = get a large duration cam. easy done.
removing the balance shaft is a bad idea, and should really only be done during a full engine rebuild - even then only if the engine is for track use (ie, at high revs all the time, so no need for a balance shaft).
__________________
Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
Check out my V6 blown stroker here: cruisies VS
  #5
Old 20-06-2008, 03:50 PM
Trade Rating: (0)
Panama Executive
ok cool. im buying an l67 and doing a full rebuild on it so i was wondering whether to put it inor leave it out. gues i'll leave it in.
__________________
  #6
Old 20-06-2008, 03:55 PM
Trade Rating: (0)
but on the buick v6 gets in the way when fitting double row timing chains i have heard. not sure if the same is with the l67.
  #7
Old 20-06-2008, 04:31 PM
Ride: VY SII HBD Calais L67
Trade Rating: (0)
chargedvx6 Executive
I assume if you are doing a full rebuild that the complete assembly will be balanced? Get the balance shaft out of there and it is one less thing to chew up power. There are many debates on this but one thing is for sure, if the engine is bein machined to balance, the balance shaft will certainly be obsolete.
BTW, the balance shaft isn't actually measured and weighted to suit each engine it goes into with the aim of perfect engine balance, they are a mass produced device that is there to add more reciprocating mass to absorb harmonic vibration and internal engine resonance in the mid rev range.
YT sells some stuff to help with the removal of the shaft
  #8
Old 20-06-2008, 04:36 PM
Jaseppe's VR's Avatar
Ride: VR ute 5speed, locker
Trade Rating: (0)
Jaseppe's VR Executive
Quote:
What stuff do you mean by this? Do you even need any special tools to remove the balance shaft out of an ecotech or buick engine?
  #9
Old 20-06-2008, 05:09 PM
Trade Rating: (0)
Nah, no special tools (outside of what is needed for a cam swap) but the balance shaft has an oil feed that needs to be blocked after removal. Yt sells the perfect sized plug but there are numerous ways to block the feed.
  #10
Old 21-06-2008, 10:23 PM
OZ38's Avatar
Ride: VY UTE 5spd
Trade Rating: (0)
OZ38 Executive
Alot of guys have removed the balance shaft on stock L67's & fitted a double row timing chain set. The only thing I have heard is the idle is a bit lumpier when cold on first start ups. Once warmed up it is hardly noticeable. My stock manual ecotec idles reasonably rough anyway with the balance shaft in. Probably more than some engines with the shaft removed.
I would only bother removing the shaft if I was adding a double row timing chain set.
Deek
__________________
Aussie Aussie Aussie, Oi Oi Oi .
  #11
Old 22-06-2008, 03:06 PM
Trade Rating: (0)
i thought the balance shaft bearings in a buick motor was splash fed not presure fed?
so you cant just pull it out you need to install like welsh plug type thing?
__________________
  #12
Old 22-06-2008, 06:10 PM
OZ38's Avatar
Ride: VY UTE 5spd
Trade Rating: (0)
OZ38 Executive
Quote:
The earlier type (Buick) is a splash type oiling for front & rear ball bearings. The later type (ecotec) has a front ball bearing that is splash oiled & a rear plain bearing that is pressure oil fed.
so you cant just pull it out, you need to install like welsh plug type thing?
Correct for the ecotec engine as it will have no restriction on the oil feed hole. The down side would be when engine is warm the oil pressure might drop away a bit to much at idle, as the oil takes the easiest path of least resistance.
Deek
__________________
  #13
Old 23-06-2008, 10:07 AM
REV-231's Avatar
Mr Gilly & his Lumpy v6
Ride: '97 VS II V6 M5
Trade Rating: (0)
REV-231 Executive
on the ecotecs... just remove the balance shaft gear so it will no longer be driven. Leave the balance shaft itself in the motor. saves having to put welsh plugs in.
__________________
Gilbs
The $4000 granny special has come a long way!
[REV-231] Cammed Ecotec 5 Speed= 187rwkw na...
My car:http://forums.justcommodores.com.au/...custom-vs.html
  #14
Old 23-06-2008, 03:51 PM
Trade Rating: (0)
Panamas' doing a full rebuild so it's a P.O.C. to do when the engines all apart anyways.
