| V6 Development And Modification All your V6 Development and Modification Questions answered here |
19-06-2008, 12:53 PM
Ride: N/A
stage 2 crow cam
hey guys just a quiky
how much am i looking at for a stage 2 crow cam? for vn v6 series 2.
thanks.
19-06-2008, 06:04 PM
Moderator
Ride: VP, VN wagons, E21 318i
Crow Cams
CrowCams Pty Ltd
16 Colbert Road, Campbellfield
Victoria, Australia 3061
Phone: +61 (03) 93570469
Fax: +61 (03) 93570001
Email: sales@crowcams.com.au
__________________
Quote:
[17:50] {Gaybar} i had some fun lastnight <----- Mack
[17:50] {hakhawk} hence the name
ɹıɐɥɔ ɹnoʎ ɟɟo uǝllɐɟ ǝʌ,noʎ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
19-06-2008, 06:26 PM
A 4 and a 6... Wheres 8?
Ride: 1991 VN Berlina & MY96 Subaru Liberty GX
Dont get it. Get a custom ground cam from Wade or Crow instead.
I have a stage 2 crow cam and it was a waste of $$$ Much better off with a custom grind.
19-06-2008, 06:29 PM
Ride: GMM ENHANCED VT SS 5.7
stay away from crow all together. had a stage 3 in my vs goes alright but nothing special for the money. go with wade or someone else. ur better off getting some roller rockers then a crow cam lol
19-06-2008, 06:41 PM
Moderator
Quote:
depends what you get from them, their "stage" cams arent anything flash, but doing it properly with a custom grind will be worth it. roller rockers will only give you lift, not different duration and such, and since theres only 1.8:1 rockers available for vn motors, a custom cam is usually the better choice.
__________________
19-06-2008, 06:50 PM
As said, custom cam>rockers but definitely get a custom ground cam!
Wade are a pain to contact, you'll have to atleast ring them. Crow are easier via the net and email.
19-06-2008, 07:00 PM
Quote:
yeh i was only kidding around but i dont really thing its worth it on the v6. it ended up costing me a bit over 4 grand to get my cam including tuning and heads etc. you would be much better off saving a bit longer and getting a raptor supercharger. if ur going to do the work its gonna be cheaper of couse and then its probably worth it.
22-06-2008, 03:11 PM
Ride: VR ute 5speed, locker
with these custom grind cams can you get them to supply you a memcal like the crow stage XX style ones do? or do you need to go get yoiur own tune?
22-06-2008, 03:23 PM
ull proabably need to get a tune made up. either a mail order own or a real time one on the dyno. i dont think the people that make them will supply u with the memcal.
22-06-2008, 03:55 PM
Ride: VS Equipe series ll
Quote:
you dont really want an overpriced mail-order anyway in that circumstance - your better off paying the couple hundred more for a kalmaker tune done in real time on your own engine for better results and the peace of mind that the tune is spot on with the afr's.
__________________
Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
22-06-2008, 04:04 PM
Ride: VP Executive R-spec
On the V6 the fuel ratios hardly change at all with a mild cam and stock heads, they just take a little bit more on the top end but it's nothing huge just adding .5-.8 of a point to the top end will be fine. But go at least the Wade 992a. Which will be anywhere from 120 to 125rwkw on stock heads. 135-140 on good heads and you can add 5-10 for a manual box
__________________
VP executive-R 0-60mph 5.36 11/10/07, PB ET 9.101 1/8th mile at Southcoast raceway 30-11-2007
VN Lexcen GL 0-60mph 6.95. 1/4 mile 15.37 @ 91 mph: calculated rwkw 114
VH SL/E 202 Auto 0-60mph 13.5
Aiming for 4.5 and to defeat stocky in the 4.9 second challenge, NA for the win
My VP, going fast on the cheap
22-06-2008, 04:41 PM
would you be up for doing a tune foam on my VR v6 when i do get round to installing a cam?
22-06-2008, 08:01 PM
Supercharged
Ride: Black VN S1 MANUAL
Just a Q does a S1 VN to VR take the same cam? i dont think they do, but what about a custom grind cam would a VN s1 fit a s1 VR?
__________________
~ VN POWER ~ Click the scales
