Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: Extreme V6
    VY V6 Ute
    Jul 2008
    Cairns
    Default Extreme V6
    Hi, is there any on out there who's working on V6 engines and producing serius HP, I have developing my VY ute V6 for the last 3 years currently we are getting 393 rwhp with a supercharger
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Quote Originally Posted by Matchport View Post
    wow man thats a nice number im hoping to 255 rwhp on mine when i fit the blower! what have ya done
    VY V6 Ute
    Jul 2008
    Cairns
    We are running a steel crank from the US rated to 800hp we modify this, internal balanced ( No Balance shaft) 5.7 H beam rods Forged pistons, S/S valves Oversize
    T trim at this time belt is slipping at 17 psi engine RPM is 5500, computor is a SM4 wired in the system
    VSSECO is offline Underdog rebuild
    VS - 6 pots, 5 cogs
    Aug 2007
    VIC
    This sounds very ineresting! I'd love to hear some more info on this engine. Got any dyno footage?
    Mar 2008
    Hey matchport.Was that your ute at Cairns all Holden Day?Looks and sounds awsome if it was.
    VY V6 Ute
    Jul 2008
    Cairns
    Mar 2008
    Nice bit of work mate.That was my silver vy ute parked behind you.I wanted to catch up with you but every time you were about there was a heap of people hanging off you.lol
    VY V6 Ute
    Jul 2008
    Cairns
    Mar 2008
    VY V6 Ute
    Jul 2008
    Cairns
    I,m Working also on a N/A engine, crank is 4340 rods are billet (Argo) with flat top pistons , inlet is 1.9" S/Steel ech 1.6" S/Steel cam power is 4000-7500 rpm, Should see approx 300 hp at the bags
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    goodluck with that one man
    just wondering though - if your blown engine with 17psi+ (im guessing from what you said about the belt slipping at 17psi) shoved down its throat makes almost 400hp. what on earth is going to get an n/a engine up to 300hp?
    seems optimistic to me, but id love to hear the plan for it all the same.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    With a big stick and some decent compression, 300 hp at the treads could be possible! It will take revs and lots of them though. Would definately be a pig of a street engine.....
    VY V6 Ute
    Jul 2008
    Cairns
    You have it we are looking at approx 7500/ 8000 rpm to get this. some of the stage II Buicks at 8500 rpm getting approx 450 Bhp
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    thats some decent numbers. i notice you refer to the yank parts, they use slightly different names for there V6 engines there S1 engines is the same as our buick 3800 engines used from VN to VR there s2 buick engines are what we call the ecotec. it'll be good to see someone hit the 300rwhp n/a with a V6.
    damn yanks, cheap, high quality engine parts for the masses. who cares about global warming
    Body by Holden, Soul by Brock
    the Legend will live forever
  15. #15
    VY V6 Ute
    Jul 2008
    Cairns
    Good to see Immortality for your support, I believe it can be done Ill get some pictures and send this to you on the N/A sofar and the running Charged unit in my VY
  16. #16
    Apr 2006
    Auckland NZ
    soemones gotta break the barrier n/a and then everybody will know whats required. with the tough bottom end parts you have from the US it's only a matter of time before you hit the mark.
    you seem to have a good supply of US parts, do those yanks have some decent heads for the ecotecs?
  17. #17
    VY V6 Ute
    Jul 2008
    Cairns
    Aluminium head are on a series 2 (Ecoteck) engine as we speak, valve are moved and porting is spot on, I think in the next 13 weeks we can see the heads
  18. #18
    VY SII HBD Calais L67
    Dec 2006
    If these heads come through they will be a mile stone for Ecotec development.
  19. #19
    VY V6 Ute
    Jul 2008
    Cairns
    The alum heads should take 2.05 inlets at the moment best dyno run was 450RWHP cost $ 1200.00us
  20. #20
    Dec 2006
    Ecotecs take 1.90intakes max. 2.05 is an improvement as long as the alloys can flow enough to match the valve diameter. Flow rates @ lift?
  21. #21
    VY V6 Ute
    Jul 2008
    Cairns
    problem with cast heads and 1.9 inlets is hardfacing on seat is removed you require upper lube to make it last.
  22. #22
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    These aluminium heads sound like they could be the goods when they are finally sorted.
    Great power figure you got, how does she drive.
    Like someone else said you need to start a proper thread on your ute with all the specs and pics, except the secret ones.
    looking forward to more info and hopefully some pics.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  23. #23
    Apr 2006
    Auckland NZ
    cheers mate. looks like you got all the fruit on there. howz the electric water pump work out. it can only be a matter of time before we see the magic number appear
  24. #24
    VY V6 Ute
    Jul 2008
    Cairns
  25. #25
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    The original post that you made is what happenes when you make a new thread. If you make a new thread in the my ride section for your model you can post all your info and pics for us in there.
  1. road rage(to the extreme)
    By flyen in forum The Pub
    Last Post: 17-12-2007, 11:45 PM
  2. Optimax Extreme, reviews?
    By simc in forum General
    Last Post: 22-04-2006, 08:00 AM
  3. 100 Octane - Extreme
    By J2112 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-02-2006, 08:47 PM
  4. Optimax Extreme
    By mytag5 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2006, 08:46 AM
