Results 1 to 12 of 12
Thread: Help, Pod filter install on VT 3.8 with LPG system.
    VT Berlina 3.8lt V6
    Jul 2008
    Adelaide, South Australia
    Question Help, Pod filter install on VT 3.8 with LPG system.
    hi all, i am a super newbie to all this performance mod stuff so bare with me. I have a VT berlina 3.8 on gas and i have attempted to install a pod filter. However without any knowledge and not knowing who to ring for advice, without getting the hard sell put on me, i just follow the minimal instructions on the flexable memory pipe that i bought with the filter. As i said im knew so everything i was doing was expreimental for me.
    Ok i attached the Pod to the air intake line that runs to the motor, then i attached the flex pipe to the other end of the pod. (yes i did remove all the old air filter box and air intake system before starting. lol) ok having done that i stretched the flex pipe down to the bottom of the engine bay and stuck it through the bottom, temporarylt fastend it in place, so's to catch the flow of cool air from under the car. So far all had seemed simple enough, when i started the car, on petrol, it started nicely, (even though there was no air temp sensor attached anywhere) i proceeded to give it a couple of revs and it seemed fine so i took it for a test run. I felt a fairly big difference in power output to what it was before on petrol however when i attempted to switch it to gas the car just died in the ass. It wouldnt start on lpg and was quite rough whilst turning over, so after trying to start it a couple of times i felt it best not to push my luck any further and put it back to petrol. It started no probs and i drove straight home to try to source out the lpg problem and thats what brings me here...to you... and this awesome commodore site.
    Please help me! Is it because the air temp sensor isnt connected to anything?
    Is it possible to connect the sensor to it as it is without making up a box around the pod?
    If i have to make up a box will it inprove the power more or take it away?
    Because i mainly run my VT on lpg does that limit the mods that i can do to get better perfomance?
    Thank you for your time and patience.
    Gabriel
    PS Please be gentle, this is my first time. lol
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Smile Help, Pod filter install on VT 3.8 with LPG system.
    Ive managed to jam the thermostat sensor into my pod without it falling out after 2 weeks, doesnt really matter there that sensor is located aslong as it is connected to the wiring or you will have your engine light stay on.
    Does your engine light come on and stay on?? If so I would recommend checking the air-flow sensor and thermostat sensor making sure their connected properly....
    Not 100% sure here but if your LPG was working before you installed the pod then I would say its in the computer.
    Also check that you havent knocked anything on the intake manifold
    VT Berlina 3.8lt V6
    Jul 2008
    thanks for that. ill try it out and see how it goes. the engine light never came on at all whilst running it on petrol, thats why i assumed everything was ok at first. the gas was running fine before the mod so ill go back and check if i have disconnected anything else by accident. The sensor isnt connected at all, its accually sitting in the boot of my car with the other parts. lol
    cheers
    Gabriel
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    lol yep youll need to get the sensor back on...
    The computer would have picked up on the missing sensor,
    Check ur engine light again though it should have come on... you might have a blown cluster bulb if it doesnt
    VT Berlina 3.8lt V6
    Jul 2008
    ok i managed to fix the problem with the help of your comments, i unattached the flexi pipe from the pod and inserted the air sensor snd then reattached the pipe, now all is running nice and smooth. thank you again.
    Gabriel
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Kulwinder is offline Kulwinder
    VX Acclaim Wagon
    Nov 2011
    St Albans
    Hi there
    I am having same problem. With my car.
    Not commodore but other one Hyundai Grandeur XG.
    It's duel fuel. And I installed a Pod Air Filter.
    After that it runs on petrol better. But on gas it is dying.
    I have checked all the plugs and sensors. They were not even touched.
    They are on right place. I just put a tree inch dia pipe. And put a pod filter in front of it.
    What can be the problem.
    Plz help.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Quote Originally Posted by Kulwinder View Post
    Hi there
    Plz help.
    Idle mixture settings will change with mods to the intake the pod filter will offer less restriction than the air box and will lean out the idle settings
    vx executive series II 3.8 ecotec
    Feb 2012
    sippy downs
    you can buy a ecotec pod adaptor for 49.95 from autobahn that the sensor just clips into would be your best bet but you best bet would be a k&n panel filter unless you have a decent cold air induction for the pod =] hope this helps
    VX Acclaim Wagon
    Nov 2011
    St Albans
    thanks very much guys...
    yeah you are right. i was thinking same. I should retuned it. because pod filter allows more air to come in throttle body.
    Air goes in before Gas. thats why it dies..
    I will go retune it
    thanks......
    L67 Calais's Avatar
    L67 Calais is online now Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    Plz help.
    I see your problem.........
    MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
    NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
    Quote Originally Posted by wraith View Post
    Mace spend time and money developing a good product and making sure there's gains to be had. Backyard mechanic wants to make wood blocks. Discuss.
    1998 VT Commodore
    Jan 2012
    Heathcote
    Drill a hole into the CAI tube to the throttle body and...glue it in there? Like, directly behind the pod filter.Or use a cable tie to hold it in place(might need 2, joined together) in the same hole.
  1. My Custom Boot Install + My System.
    By venomous in forum Car Audio
    Last Post: 14-09-2011, 10:55 PM
  2. pod filter install, help needed
    By pHiLix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2009, 07:06 PM
  3. DIY System Install Questions
    By Radar in forum Car Audio
    Last Post: 22-12-2006, 12:05 PM
  4. HOW TO install a pod filter on vs 3.8l
    By TOBSTA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-09-2006, 08:28 PM
  5. STandard AIr filter or K&N POD/FIlter
    By KDB1972VT in forum General
    Last Post: 29-07-2005, 11:16 AM
Tags for this Thread
