Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Modification and Development > V6 Development And Modification
V6 Development And Modification All your V6 Development and Modification Questions answered here
Reply
LinkBack Thread Tools Display Modes
  #1
Old 20-07-2008, 02:07 PM
Ride: N/A
vt stocker Executive
Default No start, after throttle body change?
Hi guys, just when ans swapped my 69mm throttle body on the wifes vt back to the orginal to save a bit on fuel, it all hooked up and when I turned the ignision nothing, and the enigine light is on, on the dash, HELP??
I have change throttle bodys before with no problem but this time I have no idea whats gone on. nay ideas?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 20-07-2008, 02:25 PM
Classifi3d Calais's Avatar
9-11-08 CRUISE FOR KEBAB
Ride: VE SV6, 52 Morris Coupe
Classifi3d Calais Calais
does it start if you put the original back on?
check the TPS and IAC. Also check the code thats being given by the engine light.
  #3
Old 20-07-2008, 02:29 PM
Ride: N/A
tried putting the 69 bak on, same thing there is a slight click or ticking when the ignision goes on, I thing some thing is up with one of the sensors- on the tow truck in the morning to the mechanics, looks like the wife will be late for work, I'll be popular!
  #4
Old 20-07-2008, 02:55 PM
go to the how to section to learn how to read the error codes. See what comes up and let us know.
  #5
Old 20-07-2008, 02:59 PM
Not_An_Abba_Fan's Avatar
Ride: MY08 Outlander XLS
Trade Rating: (0)
Not_An_Abba_Fan GrangeNot_An_Abba_Fan GrangeNot_An_Abba_Fan Grange
You haven't bumped a relay or a fuse loose have you?
__________________
It is better to be silent and thought a fool than to open your mouth and prove it.
Wholesaler of exhaust, suspension and brakes.
  #6
Old 20-07-2008, 03:50 PM
Ride: N/A
I don't have a lap top and harness or a snap-on scanner- how will i tell what codes it is saying are the problem?
  #7
Old 20-07-2008, 03:55 PM
sircruisealotVS's Avatar
Ride: VS Equipe series ll
Trade Rating: (0)
sircruisealotVS MonarosircruisealotVS Monaro
Quote:
go to the how to section and it will explain - its easy, all you need is a paper clip and access to the net (which you obviously have, lol) to find out what the codes mean.
if you disconnected it, did you plug the maf back in (the silver thing in the intake pipe)? i cant think of anything else which you would touch when doing a t/b swap which would stop the car from being started.
__________________
Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
Check out my V6 blown stroker here: cruisies VS
  #8
Old 20-07-2008, 04:00 PM
Ride: N/A
Didn't touch the maf sencor, took out the big black flex pipe in between the throttle body and the MAF there are 2 sensors you must unclip and take out of the T/B it self to change there the only things I touched, apart from the vac hoses (2) of course.
All so how will i find out what codes? with out a scanner to plug into the car???
  #9
Old 20-07-2008, 04:07 PM
http://forums.justcommodores.com.au/...s-revised.html
  #10
Old 20-07-2008, 05:50 PM
Trade Rating: (0)
yeah, they're the iac and tps. the car would still start without them working properly. it wouldnt run very well, but it would start up.
i dunno wtf you've done man.
as for the codes, classified calais has linked you in the above post, read it.
__________________
  #11
Old 20-07-2008, 07:18 PM
Ride: N/A
Thanks heaps for all your help, was just about to try the paper clip thing, and the RAA man showed up, he had a look over it all, did a few minor tests them put a piece of wire into the holes where he had removed a relay and it turned over? so he said it must be a securiy code, some things not letting it start, then I saw it (BLOODY WIFE) the trans is in 3rd, she can home late last night didn't put it back in park, and I just popped the bonnet and when to work this arvo, when it didn't start I just presumed it was some thing I'd done, so have a laugh boys this ones on me, if ever these a problem go RIGHT back to the start and check EVERTHING, even the basics like the car being in park, have a good night, what a tosser!
  #12
Old 20-07-2008, 07:20 PM
hahahah oh dear
  #13
Old 20-07-2008, 07:22 PM
Trade Rating: (0)
hahaha, well at least it wasnt anything majorly wrong then. it wouldnt be the first time someone has tried to start an auto in gear and thought there was something wrong mechanically.
__________________
