| V6 Development And Modification All your V6 Development and Modification Questions answered here |
25-08-2008, 11:39 AM
Mr Gilly & his Lumpy v6
Ride: '97 VS II V6 M5
Cammed v6 exhaust
Got my VS tuned a few weeks ago, and my tuner suggested i upgrade my exhaust... Again...
At the moment it has Advance extractors (just like HM's) 2inch collectors, twin cats into single high flow muffler, single 3 inch out to the back. Goes and sounds sweet as.
These are the mods:
tuned Delco ecu, 1.8 YT Ultra-lite rr's, YT moly pushrods, Custom Tighe camshaft 225@ .050, Crow level III springs, moly locks and retainers, rollmaster timing chain kit, recon stock spec heads, S/C V6 CAI, K&N filter, VX injectors, Ported & modified AFM & throttlebody match ported to plenum, ported intake manifold, Walbro GSS342 fuel pump.. i thinks that all... lol. and 5 speed too
- 240rwhp (179rwkw) on 91 octane Shell
Im currently chasing some 2nd hand pacemakers. also, im looking at upgrading from twin 2 inch to twin 2- 1/4. Then back to single..... as before
Ive been stewing over it for a few weeks now..
*Is it worth it?
*Will there be any gains?
*Should i just stick with what i have?
25-08-2008, 12:23 PM
9-11-08 CRUISE FOR KEBAB
Ride: VE SV6, 52 Morris Coupe
i think you could leave it with what you have. Maybe spend the $$$ on some head work
__________________
VE SV6 Manual
25-08-2008, 01:00 PM
Ride: MY08 Outlander XLS
You would be losing exhaust velocity where the twins go into single. Putting bigger headers on it and running twin 2 1/4" into single 3" is definitely better. But where do you draw the line? Spending more on the heads is pointless until you get the exhaust working.
__________________
It is better to be silent and thought a fool than to open your mouth and prove it.
Quote:
Originally Posted by DannyboyDS
Wholesaler of exhaust, suspension and brakes.
25-08-2008, 01:44 PM
Ride: VN Calais 5.0, UC Torana L67, WB Ute EFI 5.0
Well, the problem is that twin 2.25" will flow more than a single 3". So the single 3" will be a restriction.....You would be much better off going twin 2.25" all the way!
25-08-2008, 03:01 PM
The exhaust will have cooled enough to take up less space. By going twin 2 1/4 into single 3 keeps the exhaust velocity up.
__________________
25-08-2008, 05:14 PM
I would still go twin 2.25" all the way over a single 3".....
I have a single 3" on my L67 and if i had my time again i would not go a single 3", i would definately go with the twin system. However it would be twin 2.5" though. Having said that, i'm not about to replace a perfectly good exhaust....When it rusts out it will get replaced with twin 2.5"
25-08-2008, 05:19 PM
Quote in context why don't you.
Twin 2" into single 3" doesn't work. Twin 2 1/4" into single 3" does.
__________________
25-08-2008, 05:30 PM
My mistake, thats not the way i read your posts.
25-08-2008, 05:50 PM
OK, I should have clarified.
__________________
26-08-2008, 02:03 AM
P's
Ride: VSII BERLINA L67 V6 S/C
get difilippo headers they make the biggest for the vs
__________________
VSII Berlina L67 V6 S/C
Cooler, Cam, Stage 4 Heads
Awaiting Tune....
View Photo Album
26-08-2008, 06:23 PM
Ride: N/A
i find it hard to beleive that a standard vs with a cam and rockers is pulling 180rwkw.
what do they pull stock 100rwkw 80rwkw seems abit sus. id expect maybe 150rwkw
26-08-2008, 07:12 PM
You don't know much about the ecotec then do you.
__________________
27-08-2008, 10:17 AM
i get that a lot....
made 150 without a cam
Check the 1st post... doesnt read very stock to me?
