I'm running a sc loom and computer with it i got the whole conversion but i have a t5 behind it insted of the auto. yes that may help cause its either an earth or power that i'm lacking. I'm pretty confident that i have one of the earths because when i test the injector plug i get power and earth through the plug. which i'm assuming that the circuit i have is the main one but dose anyone know where the other earth is that the curcuit switches to when the injector pulses.
vs berlina. are you talking about the plug that is under the glove box near the pcm cause that might be my problem cause at the moment mine isn't hooked to anything, and if so could you please tell me if you know how it was hooked up it could save me alot of time.
thanks
