| V6 Development And Modification All your V6 Development and Modification Questions answered here |
01-09-2008, 12:54 PM
A 4 and a 6... Wheres 8?
Ride: 1991 VN Berlina & MY96 Subaru Liberty GX
Twin AU Thermo's to V6?
Hey guys,
Just wondering how easy it is to install the twin AU thermo's on a V6. Only really curious about the wiring.
Seeing as the V6 uses a thermo fan anyway, can you just wire the AU thermo's to a V6 plug then have it run the same as the standard fan plug and play?
01-09-2008, 12:59 PM
Tells it like it is.
Ride: VE SS-V, VP SS
Should be quite straight forward - refer to my VP thread below in my sig. You will need to alter the fuse as the single stock fuse is not enough to power the twin thermos. Why do you want to do it? I didn't think the V6's had overheating problems???
Reaper
01-09-2008, 01:42 PM
crappy ol' VN driver
Ride: VN3.8 5spd/VSII3.8/VH5.0
as reaper said, just increase the fuse size, because the V6 already has a thermo setup the rest has been done for you. there really isn't anypoint however as the standard thermo is more then capable of doing the job for a V6 unless your gonna front mount a turbo or something and need the room
__________________
Body by Holden, Soul by Brock the Legend will live forever
quote of the week
Quote:
Originally Posted by VT-565
why don't you want to go forshed induckshun?
01-09-2008, 02:15 PM
Quote:
Reaper
Ah awesome. Its not for the V6 as im not keeping the V6... So its a question about using the V6 wiring for the thermo more than anything.
I found the post in your thread ( http://forums.justcommodores.com.au/768415-post142.html). Just wondering what amp fuses you used, and if you've had any problems to date?
01-09-2008, 02:22 PM
All Green Again
Ride: 88 V6 Wagon, 89 V6 Sedan, 91 V8 Sedan & 05 VZ V6
Quote:
Are you hatching a V8 Dylan?
__________________
Self Confessed VN Tragic - My V8 http://forums.justcommodores.com.au/...-91-vn-v8.html
88 VN Wagon 3.8 Auto L3 Dash Calais trim CAI + Foaming Tune
89 VN Exec Auto 3.8 L3 Dash in Hot House Green too
91 VN Sedan 5.0 Auto L3 Dash Climate Control VR Clubsport 199 Dash Tag CAI + Foaming Tune #3!!
05 VZ Exec Sedan - with a WL dash
01-09-2008, 02:41 PM
Quote:
Im in the process of gathering parts but I won't be starting the conversion until mid semester break next year. But I want to have everything ready by then (lots of saving to do  )
01-09-2008, 03:35 PM
Ride: VP Executive R-spec
The boy's commiting himself to big time go fast so he need big time cooling
__________________
VP executive-R 0-60mph 5.36 11/10/07, PB ET 9.101 1/8th mile at Southcoast raceway 30-11-2007
VN Lexcen GL 0-60mph 6.95. 1/4 mile 15.37 @ 91 mph: calculated rwkw 114
VH SL/E 202 Auto 0-60mph 13.5
5-12-08 Friday night street drags can 8.99/13.99 be done on a 2.5 inch exhaust? that is the question that will be answered
Download the flyer for the next street legal drags
http://www.southcoastraceway.com/ima...dec-5-2008.pdf
My VP, going fast on the cheap
01-09-2008, 03:38 PM
All Green Again
Quote:
What a dill I am some times - twin thermos for a V8 .......
__________________
01-09-2008, 04:03 PM
The wiring and relay is there with the V8. I used 2 x 30amp from memory and wired it direct to the relay box as the wires looked a bit light weight that went in the loom. They only draw high current at startup and within a sec are down to less than 10amp for the pair.
I haven't had any problems what so ever with them. They come on at 91deg and turn off at 89. Doesn't take much to keep engine temp almost exactly constant. You may want to spread out those numbers a little to avoid the fans kicking in and out so much.
Reaper
01-09-2008, 04:11 PM
Excellent, thanks for the help Reaper.
Ride: VR Clubsport 5 speed, VN V6
reaper, what do you need to change in the tune to get them to run on the v8. i have twin thermos on mine, but theyre on all the time so i need to change that
01-09-2008, 04:25 PM
Quote:
Assuming you have a 5D def file and you have wired it thru the correct relay....
KFANTCH Fan 1 on = 91 deg
KFANTCL Fan 1 off = 89 deg
KFANKPH = 0
If I get a few min I'll do a detailed "How To" on thermo installation over the next few days.
Reaper
