i thought so too, but castle hill exhaust tried it and their was no where near enough room. they had to make it custom. dont think they have them ready made
Depends on how you do it. I dont have the specs on the alloytec engine bay etc so i cant draw anything up. But if you got a OTR from an ls1, then extended the pipe that leads into the TB and included the MAF you should be ok
The problem at the moment with the Alloytec is that there isn't sufficient space between the engine and the OTR CAI shute to fit in a MAF.
The LS1's go mafless when using the OTR CAI.
As Mattio said, once someone comes up with a simple mafless tune for the alloytec then using the same OTR CAI as the LS1/2's shouldn't be a problem.
