ok.... dont know what made me think of it.. but does anyone remember the blower used on the 2 door XB from one of the mad max movies??
the one with the ON/OFF switch??
is this possible, if yes... does anyone make them??
It wasn't a sc14 on the car tho !, hakky just means the sc14 can work with a clutch like that (stock it does)
oh dear it's a wieand 14/10 gm root's type.
the clutch setup is the same as an aircon electric/magnetic (but fake in the movie)
as they used a gear shift/range shift of an older type roadranger.
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
Yeah Im pretty sure the Mad Max 'charger was an enpty unit mounted over a carbie with an electric motor and pulley system to make it appear it could be turned off and on.
Would be a cool thing to see if they could ever figure it out in real time.
Can you put a roots type supercharger on a buick v6?
I've been thinkin about mounting 2 throttle bodies on top of a standard manifold and mounting a supercharger type hat on top, but that's pretty lame.
Is it possible to top mount an sc14 and make it appear like a roots type?
I just love the old school look.
My Ride:
'94 VR V6 BT1. 15" roh with 225's, stocky with bellmouth removed, OTRCAI, homemade airfilter, B&M Stage1 shiftkit, .490 boost valve. Corvette servo.
Lappy runnin EFILive in a semi stock interior.
WANTED: VN/VP/VR/VS Standard
Memcals.
WANTED: Standard front bar from VR/VS. Prefer alaskan white but will take anything.
Newcastle/Maitland/Central Coast.
Email me
hyp3r4l3rt@hiptop.com.au
Old school look? scrap your throttle bodies and injection then lol
I've seen a 6/71 on a chev V6 with carbs, looked the biz with the bonnet down, looked a bit small with the bonnet up lol.
MY RIDE 96 calais
http://forums.justcommodores.com.au/...96-calais.html
ALSO MY 1972 VALIANT CHARGER IN THE BUILD
http://forums.justcommodores.com.au/...t-charger.html
Yeah, as far as I'm aware, it ran an electric motor to run the blower. LOL
I wouldn't bother with being able to turn it on and off. Just run a by-pass valve that opens under vacuum and closes under boost. Just like the factory L67 setup. This will give you better economy during normal cuise modes and full boost under heavier throttle situations. The switch is in the right foot. LOL
I love being blown!
VT Calais with a Whipple blown 4.2L stroker.
Mods;
-Pro race 4.2L Pro-stroke stroker kit, prepared and assembled by Pro-Stroke.
-Custom grind Ivan Tighe cam.
-YT Ultra lite rockers
-YT customised whipple adapter.
-3.3L whipple blower.
-TRK Icebox and by-pass setup.
-TRK 2" extractors, 4" collectors and cats, into dual 3" X-Force exhaust.
-Heads are currently standard.
-EMS 8860 ECU tuned by CV Performance
400rwhp and climbing....
Just do an L67 conversion.
You could run an SC14 blower in the valley, but the cost of it unless you could do the fabrication work yourself would be quite high. Not really worth it imo. Better off going the L67 route with more hp potential down the track.
If you wanted to run a carby setup, you could run a blower like mine.
Whipple have a range of blowers that have what they call radial feed. It's simply a quare bore bolt pattern opening ontop of the blower. You can run them as carby or EFI. I've got a 2000CFM four barrel throttle body sitting ontop of mine with an Enderlie bugcatcher ontop of that.
I love being blown!
Mods;
Maybe our mate only wants the looks just like MM
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
LOL, yeah. Never thought about that. haha
If that's the case. do the mad max setup. Get an empty casing or a buggered casing. POlish it up and put a window wiper motor inside it. Run an idler pulley under the blower pulley. Ta daaahhh![]()
I love being blown!
Mods;
