Results 1 to 24 of 24
Thread: anyone know where i can find the beige cap fuel injectors off the early 90's magnas?
    vr commodore
    Sep 2008
    Default anyone know where i can find the beige cap fuel injectors off the early 90's magnas?
    its for my v6 vr commodore ofcourse but i need to upgrade the fuel injectors and was told this would be the easiest and cheapest way,though i've rang around atleast 20 wreckers in sydney and had no success.or if anyone has them for sale ill be interested thanx
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Dont know what wreckers you are going to but i would have assumed majority of wreckers would at least have a few early magnas. My local wreckers has about 20 of them with the cream tops.
    Why do you need to upgrade the injectors? What sort of power are you making?
    vr commodore
    Sep 2008
    Quote Originally Posted by Wagon_Wheel View Post
    what state are you from?yea i didnt think it would be hard to find but yea..umm i have just turboed the commy standard injectors aint copeing
    Aug 2005
    Mt Martha, Vic
    Oh ok, well thats understandable, but for a turbo i would be going with bigger injectors than cream tops, depending how much power its making.
    Maybe get some GENIII injectors? I think they are some where near the 30lb mark as apposed to 24lb. If your running decent amount of boost you will need bigger than that as well, which you will have to get new or if you keep your eyes open.
    Im in Victoria by the way
    vr commodore
    Sep 2008
    Oh ok, well thats understandable, but for a turbo i would be going with biggeet new or if you keep your eyes open.r injectors than cream tops, depending how much power its making.
    its only running a small t4 turbo apparently making about 260 horses but icant be certain on the power output..i got told the creamtop injectors do 28lb and the blue ones do 24..do you have the number for that wreckers in your area?i might give them a call cause sydney doesnt have any..and its only running about 8 pounds of boost
    Aug 2005
    Mt Martha, Vic
    Cream tops and blue tops both do 24lb/hr as fair as i know.
    The place is called Harveys Wreckers, there number is 0359711132.
    But surely one near you will have them, just ring around and ask if the have any early magnas with the astron motor that are injected. They should be TP/TR magna's prob other models too
    vr commodore
    Sep 2008
    hahahahe one of the wreckers just rang me up and said 50$ each injector!as if!ill give your place a call tomorow thank you!
    VX SS M6
    Jun 2005
    mine will be for sale soon after my tune 36lb super6 injectors replacing them with 42lb
    Aug 2005
    Mt Martha, Vic
    Tell him to get one up him for $50 each, you should be able to get all 6 or even 8 for that.
    A while back i priced up the inlet manifold, throttle body, wiring loom, injectors and everything from the same sort of magna, they wanted $55.
    Jun 2005
    magna injectors are no good for boost. i had them and they maxed out as soon as it hit boost. got a dyno chart that shows that too. i bought some 39lb/hr injectors and they were fine, which im selling now
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    vr commodore
    Sep 2008
    Quote Originally Posted by stocky View Post
    yea i sent ya a private message man how much do you want for them ill by the injectors off yathanx
    vr commodore
    Sep 2008
    Quote Originally Posted by VSIIBerlinaL67 View Post
    i want them asap when are you selling and how much for?
    VX SS M6
    Jun 2005
    dunno 100% im just waiting for a couple of things before i get it tuned prob sell for 200
    VP Executive R-spec
    Jan 2005
    They will eassssily do 8 psi and that's what he wants to run. I'd say your tune was going lean rather than the injectors maxing out
  15. #15
    VP Executive R-spec
    Jan 2005
    LS1 injectors and Cream tops are both 28 pound so either will do, both will make 250 rwkw + in a V8, they will handle a mild boost on a v6. And I'm sure there are 1000 magnas in the wrecking yards around Melbourne and Sydney if not more :!
  16. #16
    Jun 2005
    cream tops are only 21lb/hr, possibly 24.
  17. #17
    VP Executive R-spec
    Jan 2005
    But Stocky if they are 21 or 24 why do they give perfect air fuel ratios when set to 28 pound and why do kalmaker say they are 28 pound
  18. #18
    Jun 2005
  19. #19
    VP Executive R-spec
    Jan 2005
    nooooooooo well it doesn't really matter, the point is they are cheap, easy to get are bigger than the blue tops and they are about almost identical to LS1 injectors and they are enough for 8 psi on a V6. That's all he wants to run and I don't thnk he wants to spend 300 bucks on big injectors when he might get cream tops almost for free.
    I'm doing the tune and it's going to go the most smoothly if he uses cream tops rather than 40 pounders so don't make it harder than it needs to be . If he ends up needing a little more fuel then it's cheaper for him to just run some more pressure
  20. #20
    vr commodore
    Sep 2008
    Jun 2005
    i ran about 9psi intercooled with 39lb/hr injectors
  22. #22
    vr commodore
    Sep 2008
    and the magna injectors didnt work for ya?
  23. #23
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    yeah mate you will need bigger injectors than magna ones.
    Matt
    VP TURBO WAGON --13.04 @109mph >>>>>http://forums.justcommodores.com.au/...-vp-wagon.html
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
  24. #24
    vr commodore
    Sep 2008
    ok well any1 wanna sell a set?
  1. CLASSIC 80's and early 90's acrade games!
    By Troy711 in forum The LAN Lounge
    Last Post: 05-07-2008, 03:57 PM
  2. How to find out my fuel usage per 100kms
    By Fitzy3VSVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2006, 03:25 PM
  3. Would exhaust fume test find leaking injectors?
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2006, 10:16 PM
  4. Where can I find those fuel chrome tank caps
    By garth_rocket in forum General
    Last Post: 26-01-2006, 12:37 PM
  5. fuel light..too early?
    By vs-s2 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2005, 11:20 PM
