Results 1 to 18 of 18
Thread: ecotec cam and rockers
    vs bt1
    Jan 2009
    Melb, VIC
    Default ecotec cam and rockers
    hey guys,
    is there a good grind for a ecotec? or a specific grind? like common good grind for the 304 is 286
    and whats the deal with the hi ratio rockers? can i still use them with a big cam? just not a big ratio?
    cheers, Ben.
    vn calais, vs clubsport #137
    Jun 2005
    there are plenty of grinds for the ecotec, hit up come racing or crow cams (awaits flaming), with the rocker ratio you need to encorporate that into your cam selection, normally if you are going a big cam, a higher ratio rocker isnt really needed.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Every thread i have seen come up about this subject the wade 992a gets a high recommendation, best bet is to wait till someone who knows about this stuff comes online/see this thread
    Jun 2005
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    vs bt1
    Jan 2009
    Melb, VIC
    spoke to come racing they reccomended:
    CSBR523
    LIFT: 533ex 507in
    ex 232@.050 in 222@.050
    needs 10.1 comp tho, and rpm range 3,000 to 6,000
    vs bt1
    Jan 2009
    Melb, VIC
    also, crow and and come both said dont bother with the high ratio rockers as for there really designed for standard cam.
    Jun 2005
    Quote Originally Posted by lo-rolla View Post
    CSBR523
    LIFT: 533ex 507in
    this is a bit bigger than the 992a grind, but im sure would be a nice size on an ecotec motor, if you are retaining the standard rocker ratio.
    yes the higher ratio rockers are normmaly used when keeping the original cam profile.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    sheesh, that cam that c.o.m.e. recommended is a decent size...maybe a little too big for a streeter. what are your plans for the car?
    if its only really a daily driver then i'd go just a little smaller than that or your going to be revving the tit's off it to get moving.
    was it a hydraulic roller cam? if so, must be one of the biggest they make. you definately want a hydraulic roller if its a daily driver, way too much bullshit messing around with a solid.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    Quote Originally Posted by vn calais manual View Post
    it is way bigger than a 992a
    i would say the 992a or 1114a would be around the right size for a street driven ecotec (both are smaller that that c.o.m.e. cam).
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    i second that... dont get a cam that is too big if you are goin to drive it on the street. It can get annoying sometimes!
    and you will need some sort of stally or else it will be an absolute pain to drive
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    VP Executive R-spec
    Jan 2005
    I've been doing a tune for a well worked V6 with a 1114a12 lately, still have a way to go till it's right but he had it idling on the phone for me to hear the other day and it's not short of note at idle I can tell you
    vs bt1
    Jan 2009
    Melb, VIC
    been doing a little more research and checked out the wade 1114a camshaft. sounds like they way to go. will call them tomorrow and get a price on it.
    vs bt1
    Jan 2009
    Melb, VIC
    just another question about the wade camshaft (1114a) i rang them and there main guy is away, so he's not sure if the 1114a is a re-grind or a billet cam?
    does anyone know?
    and yes, the wade one is a hydraulic.
    ben.
  15. #15
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    pretty sure the biggest you can go on a regrind is the 992a, could be wrong but :P
  16. #16
    vs bt1
    Jan 2009
    Melb, VIC
    Cheers,
    i said (and so did the bloke from wade) that it's probly to big to regrind.
  17. #17
    VX Executive S2 Ecotec 5 SPD
    Dec 2008
    hi. i have no idea about cams lol. nice start, but i have a vx executive 3.8L manual. how much gain would i get from a cam upgrade and how much are they and where from? lol thanks heaps. seems like the best place to go to get any help
  18. #18
    TrEnNaVY's Avatar
    TrEnNaVY is offline Donating Member
    VY S V6
    Nov 2008
    so i got a vy s pac v6, worth getting a 992a on it? i got a mate that just started at crow cams so i should be able to get a good price.
  1. need advice! fitting my yt rockers ECOTEC
    By vsdore in forum Yella Terra
    Last Post: 29-04-2010, 08:21 PM
  2. rockers and pushrods to suit v6 ecotec
    By djeyecon in forum Yella Terra
    Last Post: 10-04-2008, 07:18 AM
  3. FS: Ecotec 1.8:1 rockers and subs
    By smaddock in forum Parts And Other Items For Sale
    Last Post: 06-03-2007, 05:16 PM
  4. FS: YT 1.8:1 stealth rockers for Ecotec V6
    Last Post: 14-12-2006, 11:03 AM
  5. ECOTEC Rockers
    By Sparkie in forum V6 Development And Modification
    Last Post: 16-11-2006, 12:05 AM
