Results 1 to 13 of 13
Thread: vx commodore sc14 need help
    vx commodore
    Mar 2009
    Default vx commodore sc14 need help
    hi guys i need a little help ive just bought a sc14 supercharger i intend to set it up on my vx commodore my mate is doin the install but ive just got a couple of questions....
    wat size cooler?
    is the reverse plenum better?
    wat boost should i run without daminging my engine?
    please get back to me asap thanks heaps guys
    VN S1
    Jan 2008
    Id go a 77mm pulley and use a intercooler definetely, 700x300 but you should measure up your space to see if you could fit it. Also dont forget the tuning part and bigger injectors.
    vx commodore
    Mar 2009
    Smile
    im buting it as a complete kit it comes with
    sc14 superchargers
    - all pulleys and brackets
    - drive belt
    - BOV
    - injectors
    - throttle body relocation kit
    - pod filter
    all i need is the cooler and tuning how much is dyno tuning???
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    97 VT Exec
    Oct 2006
    Hey guys,
    Sorry for the hijack thread but its kind of related,
    I got sc14 which I'm currently about to install into my vt
    I bought it with a 8psi pulley..
    if I run it through a intercooler the pressure will drop to 6-7psi. (I think?)
    Will I need to upgrade my injectors and a bigger fuel pump to run 6-7 psi?
    Thanks.
    vp
    Feb 2009
    wont need to upgrade the fuel pump, tho slightly bigger injectors wouldnt hurt
    VZ SS 6 SPEED MANUAL
    Apr 2007
    WA
    Hey mate
    How much did the S/C cost ya if you dont mind me asking ??
    Thanks Mate
    97 VT Exec
    Oct 2006
    VT V6
    Aug 2006
    I know this is a reach, but u dont happen to have pics of the brackets for the ecotec dude? or dimensions? there are so many of these kits out there, but no-one seems to have the dimensions of the brackets.
    steve.
    idb
    idb is offline
    holden vx s m5
    Nov 2008
    Home built Charged VS Commodore
    Apr 2010
    New Zealand
    Default SC14 braket onto ecotec.
    Quote Originally Posted by Steve3800 View Post
    steve.
    Hay man I just made my own brakets for the sc14 to fit the ecotec only took me 2days start to finnish, I did full front mount and custom intake that I fab myself so the air flow meter and throttle body are on the right side of motor. Can send you pics of the setup if you want just get bak to me.
    2003 VY soon to be boosted
    Aug 2011
    West Auckland
    Sorry to bump into an old thread but WAFFEN SS are you able to PM me with these, or are you able to assist with making me some, I am in Auckland, thanks
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by voigta View Post
    wat size cooler?
    a 600x300x80 with 3" in/outlets will be fine, they are common and cheap.
    the limiting factor with power will be heat due to the size of the blower (5CID smaller than the M90) If the AFR's are spot on i wouldnt exceed 10-12psi because the SC14 will be superheating the air after this point and you will run into detonation/preignition
  1. 10 psi kit for sc14?
    By pandacav in forum V6 Development And Modification
    Last Post: 11-07-2010, 10:47 AM
  2. SC14 To Suit Commodore V6
    By Avi8or in forum Parts And Other Items For Sale
    Last Post: 01-05-2008, 09:21 PM
  3. WTB- crs/sc14 S/C
    By 10000_fists in forum Swap / Wanted to Buy / Trade
    Last Post: 11-02-2008, 08:02 PM
  4. Sc14 + Vlt?
    By mulligan-can in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-10-2007, 06:53 PM
  5. sc14 - where can i get one
    By vrsleeper in forum V6 Development And Modification
    Last Post: 07-05-2007, 02:36 PM
