Results 1 to 9 of 9
Thread: roller rockers help.
    vn calais, vs clubsport #137
    Jun 2005
    Default roller rockers help.
    hey guys,
    did a quick search but didnt really find much, ive got a set of YT 1.8 rockers and started installing them today, got a few qs for people that have done it before. might make me look stupid, but id rather find out for sure than something bite me in the ass!.
    now,
    q1) the yella terra steel plates they supply with the kit, do i need to use this? im assuming the plate goes on, then this small spacer with the bolt down the middle, but i notice in the drawing that them spacers are used on the adjustable types.? so i dont need this??, also. to put the plate on, all 6 rockers on that bank must be off at the same time, whereas the instructions ask u to do the rockers one cylinder at a time with the piston in TDC and continue in the correct firing order. so for me to fit this plate anyway id be going against the instructions?.
    so atm i have just removed cylinder ones rockers, and sat the YTs on there and threaded the bolt in but have not torqued. should i be using a spacer between the cast for the bolt thread in the head, and the actual rocker itself, as the thread is visible and seems odd to me? but i could just be wrong. havnt really seen them before.
    if anyone has any pictures of fully installed rockers it might help a little bit.
    and if anyone has any tips let me know!.
    cheers in advance.
    VN S1
    Jan 2008
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Quote Originally Posted by vn calais manual View Post
    hey guys,
    now,
    cheers in advance.
    Yes, you need to use the steel plates and the spacers between the rockers & pedastals. You pull all the rockers off and replace them all with the YT ones but only sit them on loosely THEN you go 1 cylinder at a time in the firing order. Pull the spark plugs out to make it easy to turn over.
    Jun 2005
    bingo. cleared that up all in one hit. the instructions really wernt that clear thats all. thanks a bunch.
    also while i am here, with finding TDC, because the motor isnt runing atm. ive just got all the plugs out and using a bent into shape cable tie to spining the motor over by hand to get as close as i can to it. is this close egnough to actual TDC for the rockers?
    Jun 2005
    Yeh, that will be fine. Your only looking for compression stroke so both valves are closed. So, if its not quiet on TDC it wont matter as long as inlet and exhaust are closed when you adjust the rockers up.
    Jun 2005
    Jun 2005
    VY SII HBD Calais L67
    Dec 2006
    Make sure to hold the rocker tip on centre over the valve stem tip as you torque em up. No biggy but it just makes for good geometry.
    VYII Calais L67
    Jun 2005
    Quote Originally Posted by chargedvx6 View Post
    no worries mate
  1. what roller rockers should i use
    By sik-holden in forum Yella Terra
    Last Post: 27-10-2008, 09:04 AM
  2. Roller Rockers .
    By Fusion in forum Yella Terra
    Last Post: 27-10-2008, 08:56 AM
  3. Roller Rockers LS1
    By minux in forum Yella Terra
    Last Post: 26-03-2007, 06:02 PM
  4. roller rockers
    By tysonsvyss in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-01-2007, 10:44 PM
