Page 1 of 6 12345 ... LastLast
Results 1 to 25 of 134
Like Tree30Likes
Thread: Stock 304, Guide to choosing a camshaft
    VP Executive R-spec
    Jan 2005
    Default Stock 304, Guide to choosing a camshaft
    I've wanted to write this for ages but it's a bit job to do properly and I didn't really feel up for it. So I think I'll do a fairly quick first post compared to how it could be and then add to it once the thread grows and questions are answered etc. Just remember I'm not any kind of camshaft expert, but I probably have more dyno printouts of near stock cammed 304s and cam specs on file and more simulator time (100sx100s of hours than anyone else) so I guess if anyones going to write about this is has to be me.
    For all of this we will be assuming a good exhaust and cam on a otherwise stock 304, stock compression, stock stall converter etc. And just writing about what is the most sensible cam for the job you want to do and why.
    A bit of a basic theory about cams on a stock 304 is that you need to work around a couple of things, first the banana manifold which has very long runners and gets quite hot and the low compression of the standard motor.
    Now in general the ideal sized basic standard kind of camshaft for this engine is something that makes power in the middle of the bananas ideal rev range and that's a normal cam of about 213/213 duration and 112 lsa, your typical Crane 276 is near this and you will often see people reccomend this as the camshaft where you peak in acceleration from standstill with a standard 304 that's kinda true if you were using cams with the same intake and exhaust durations but not if you get a bit sneaky, after this cam there's a plateau where theres no gain (you start to gain a little up top and loose down low untill about 220/220 degrees duration at which point you start to go backwards overall. By the time you reach 230/230 degrees you are going backwards almost everwhere on a stock motor (except for a very short time at very high rpm but overall the car will be slower).
    Now, You can also have cams that have more duration on one set of lobes than the other, split duration cams. So with this you can do a couple of things. Normally with a weak intake on a street motor you will use more duration on the intake side and less on the exhaust and this is a good way to go on the 304, if you have or plan to run a good intake in the future and very good exahust you can go the other way around. Running less duration on the intake is also handy on low compression motors.
    But! for some time now (since I bought my camshaft). I've realised that certain kinds of cams perform better than others on the 304, really you can hear the ones that are working better and to me the Crow 4503 allways sounded fantasic, this cam is 226/220 113LSA, has a fairly lumpy idle, it doesn't start to make more power than the stock cam untill 3500rpm but it makes good power from there on up and hangs onto the peak untill 6000rpm it does this because of the longer duration on the intake and catches the bananas "second breath" earlier than most other cams so it starts to gain again just around near 6000 rpm. but because the duration is shorter on the exhaust it's not totally full of fail at lower rpms. This is a good maximum effort cam on a stock 304, consider this the biggest cam you could get away with and probably really only for manuals with stock compression. Now if you were to use this in a auto you wont really _gain_ overall with the 4503 but you will not loose, your car will sound alot cooler and have a fair bit more top end power but it will definatly be slower off the line. Compared to a Crane 286 it will have a better idle, more torque and more peak power. Another interesting cam from Crow is the similar but smaller 4502, I don't know of anyone that has used this cam, but it follows the same theory in perhaps a more sensible sized cam especailly for an auto on the stock stall. This will run the same times as the 4503 but you will do so with 1 or two hundred less rpm on your shift points and that's allways a good thing, it'll be down a few hp on the top end but nothing much and it makes up for this with a little better low end. The Crow 4502 is 218/214 113 LSA.
    Perhaps the most popular Crow cam is the 4770 (Crow stage 2) it's 214/226 111 LSA alot of people use this cam but I don't really rate it for use with the banana manifold it's more something you would use with another combo I mean it's not that bad of a cam and all these cams are similar in performance, but this one will be a tenth slower than the other two Crows and make quite a bit less top end power so it wont be so studly on a dyno run.
    I'll add another popular Crow cam, the one with the angry idle the 4761 it's 230/230 and 109 LSA definatly on the downward slide as far as overall times goes on a stock motor but still faster than the stock cam (if you don't mind reving the thing to the moon and back) dont expect to see good times with this size cam unless you are shifting _well_ above 6000 rpm ie 6500 but most of these cams need you to shift up near there for ideal times. You could probably go with this one if a good manifold and more compression (optional) was in your future at some stage. Alot of guys with manuals get this one.
    There's a couple other popular Crow cams but I think the 4502 and 4503 are the important two when using the banana manifold.
    Moving on to the Crane cams, you have your 276, 284 and 286, we can skip the 286 here because thats only really a goer with flat top pistons and a big stall converter and not so good with the banana even then.
    The 276 will make more torque than the stock cam and a little more top end, if you are going to want a cam with a daily driver that wont see high rpm you can do better and if you want a crazy sound and overall acceleration you can also do better so it's kinda a middle man cam, nothing too exciting I guess but a safe bet you are looking at 2 tenths slower than the 4503/4502 on this one.
    The 284 everyones favorite cam loses some low end over the 276 and loses some over the stock cam, but it will hold top end power better than the 276 and over the full 1/4 mile will be a little quicker, about one tenth, so somewhere between the 4503/4502 and the 276 for 1/4 mile goodness. Over a short distance the 276 will be better, over a full 1/4 the 284 is better. Like I mentioned before the 286 is too much cam and will be going backwards so we will move onto Wade cams. I could have talked about the Blue racer cams which were the old Cam Dynamics range that Crane bought out but since Crane went broke I don't think you'll see those grinds come back again, the 276-284-286 probably will at some stage.
    I made a bit of an error with the cam I choose which was a 214-222 from Wade (kinda) this is because I allways worked out the cam on the final specs I wanted in the engine in it's final form and that's with a very good intake but with a standard stall converter so in the end it's not really so good with the banana, equal torque down low to the stock cam but very much inferior top end power compared to some of these other cams, overall it's only a little better than the Crane 284 over the 1/8th mile where I'll be using it and similar over full track.
    But Wade have a some more sneaky cams one that I really think is cool is the Wade 963A961A10 it's a tiny little thing at 203/213 but as an angry LSA for such a little cam of 110 and will make crazy grunt off the line (fair bit better than the stock cam) BUT it will also make more top end than the stock cam, this is a good cam, especially for a heavy car like a stato. Overal 1/4 mile times about the same as a 284 but better off the line and on fuel etc.
    The good thing about Wades catalogue is that there's 1000 cams in there and you can if you want choose an intake lobe from any one of those and an exhuast lobe from any other and make your own cam from those, that gives you just about any grind you could want, I'm sure all the other smaller cam grinders will do the same from their catalogues.
    Another great cam for the 304 is (oddly) a cam that's often used in the RB30, the Wade 818B1522C this is another of these turbo type grinds that happen to work well with the banana manifold this in theory should be the fastest cam (but almost identical times to the 5403/5402) we have talked about so far, specs are 222/212 109.5 LSA, the bottom end will be a little stronger than the Crows.
    Other "turbo grinds" Wade do are the Wade 1522B1147B very similar performance to the above but 110 lsa and more duration at 224/218 if you wanted a more safe bet you would go with this one.
    Anyway that's all I'm going to write today, hopefully it give you some idea about what's needed when choosing a cam for a engine where you are keeping everyting else other than the exhaust stock and remember from the stock cam to the Crow 4503 and 4502 we are only talking 2 and a half tenths and 3 or so mph but with much more top end power and more impressive dyno sheets. The bigger cams multiply the gains with a better manifold and more compression however all the above cams will no longer be the ideal cam in that case but they will be still CLOSE. And for a car that will slowly evolve I guess having a cam that can do a bit of everything is the best way to go about it. The smaller/lesser cams mentioned here will dyno around 170 rwkw and the better ones about 185 ish.
    Also I'll add something about LSA, Lobe Seperation Angle, as a rule (depending on the total duration and some other stuff) Tigther LSA's ie 108 is tight 117 is Wide, the tighter it is the rougher the idle will be and the more concentrated the peak torque hit will be. Also the tighter the LSA the better headers you need to make it work, with a wide LSA cam like the stock cam at 117, headers do little compared to what they would with another tighter cam
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    good to see you get back to this. you should do a bit about lift/ramp rates and springs to suit
    Body by Holden, Soul by Brock
    the Legend will live forever
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by immortality View Post
    Yep will add more to it as the days go by
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    So, jason, how do you reckon the Crow 4503 would go with say 10:1 comp?
    My dad had the Crow stage 3 or 4503 in his HR (when it was a 5 litre, obviously ) and to me it seemed very doughy down low and that was with a 3000rpm convertor. Although, that was with the generic Crow tune, so that could have been a factor, but i always thought it would have really benefited from more Comp.
    ParkwayDrv's Avatar
    ParkwayDrv is offline ɹoʇɐɹǝpoɯ ǝsınɹɔ ɐʍ
    VZ SSZ
    Feb 2009
    good write up mate
    Black, Red leather, 20" Pentagons, Red walls, Lowered, OTR, Mafless, 3.9s, Diff dumpers, 341rwhp...
    185i, Chasers, Flappers, Venetians, Sunvisor, Twin diff dumpers, 194rwhp...
    VP Executive R-spec
    Jan 2005
    Yeah It'll be more of a slug down low than the stock cam but that's only half of 1st gear an also partly fixable with a better tune, over the full 1/4 it'll come back but for a street car that never sees the track it's not really the right cam well really in that case the stock cam and stock everything is the right stuff
    There's 3 or 4 different cams that can be the Crow stage 3, every time someone sends me a cam sheet for a "stage 3 crow" it seems to be something different so that's a bit of a trick too, up untill 230 degrees duration at least you can allways can back equal toruqe down low as the stock cam by adding more compression, the more cam then the more you can get away with but somewhere after that you can't get it all back. A friend of mine had one of the stage 3 crows (don't know which one) and it ran a 10.1 1/8th mile on that supplied tune, then 9.2 on one we knocked up for it (first try) so there's a fair chunk or difference there
    VP Executive R-spec
    Jan 2005
    This is the Crow 4771
    This is another of the "Crow stage 3's dunno which one but probably also the 4771" Both these cars ran 9.2 1/8th miles at full weight
    VP Executive R-spec
    Jan 2005
    Here's the typical 218/222 cam in the Orange ute, the Wade 1522bc?cb? lol one or the other, the limiter is 6200 rpm for reference
    VP Executive R-spec
    Jan 2005
    And this VR had a small cam 213 duration I believe and slightly cleaned up heads, with a good twin system and x pipe, ran 9.0
    but perhaps more skillfully driven than all the other cars above, this car made 165rwkw and had plenty of dyno time
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Great write-up foamy - I don't even own, or ever intend to own, a 5L, but this was still an interesting read. All I could suggest is maybe adding some headings to break it up for easier consumption
    Rep sent your way!
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    Jun 2005
    Quote Originally Posted by greenfoam View Post
    I "believe" his stage 3 had the 4503 cam...To be quiet honest, i wasn't impressed by it at all, the only thing it had going for it was a nice sounding idle. It ran 14.5 on street tyres, which i think was rather slow (i whipped him 4 times with my stock L67 ) but, by the sounds of it a good tune 'might' have cured some of that. Bearing in mind, the HR isn't actually that light....
    VP Executive R-spec
    Jan 2005
    Moot on sc put another alternative stage 3 crow :P the 4650 in his stroker his just built for his wife to race 230/230 113 lsa, it's running a banana for now but will change later. It was built to run sub 12.5 and should do that just fine. Hasn't raced it yet but he said it runs really well, that's a good cam for a banana powered stroker. Pretty much anything with any cam can run better than 14.5 how come that HR was heavy anyway? but so it ran 14.5 if it was going to run 14.7 or 14.8 on the stock cam then he got a decent gain out of it.
    If I was me I'd definatinaly choose the 4502 if I was never doing anymore mods to the car over the bigger 4503 here's the Crow Holden catalogue anyway http://www.crowcams.com.au/media/cat...20V8%20EFI.pdf
    Jun 2005
    Any V8 HR (or any early Holden for that matter that will be engineered) will be heavy because it needs to have a 3/4 chassis kit fitted, strengthened front end & lower control arms (heavy steel) and his also had an 8 3/4 Mustang diff so it all adds up. I will be in the market for a cam to go in a Banana powered 355 soon (as you well know) so i might go with something from the Crow range.
  15. #15
    Jun 2005
    Yeh, i guess that is true, but i just thought it would go a bit faster than that. But, it didn't really feel that good from a seat of the pants perspective. It also had a 3000 stall and 3.55 gears in the diff. The exhaust probably let it down a bit too, it was only a single 2.5". It just felt like a bit of a mismatch...thats all.
  16. #16
    vq rat's Avatar
    vq rat is offline vq rat
    vn bt1 burnout weapon
    Mar 2006
    hamilton vic
    [QUOTE=greenfoam;1441206]This is the Crow 4771
    yep its a 4771 cam as i built the motor in this car about 4 years ago, and this is how its been driven since it was put in the car haha, its got some head work as well
  17. #17
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Xclent write up jason, This is very valuable, quality information. Rep given....not that you need it
    edit: i'll add rep later, apparently i need to spread my rep around to others first.
    Reaper
  18. #18
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Thanks for the info there greenfoam!
    I was definatly looking at a cam for the 304 when I start to rebuild it, so far the Crow 4503 sounds orite. Dose it lose anything over stock down low or pretty much the same?
    Something that would go nicly if you decide to add to this is recomended additional mods for each cam, say extractors and what not.
    edit: do new bearings come on these camshafts?
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
  19. #19
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by mischa View Post
    The 4503 will loose down low for sure, I think the 4502 is the one to have on a otherwise stock engine. No you don't get new cam bearings
  20. #20
    bottleinspector is offline power starved westy
    vs bt1
    Jan 2010
    liverpool, nsw
    great thread....i just bought a cam to put in my 5l, so i can get some sort of power gain until i can afford the stroker and manifold...seems i got the right cam for a stocker, 214/214 and 112LAC with springs to suit, my question greenfoam, will it be ok to drive with the tune i got from you a few weeks back or will i need another tune??
    cheers
  21. #21
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by bottleinspector View Post
    cheers
    I should drive OK I'll adjust the tune for you for not much once you have it run in so it's right
  22. #22
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    hey greenfoam what cam would you suggest for my 304 i'm keeping the stock manifold, atm i'm keeping stock pistons or as close to the stock ones as possible ( blown the budget .. ) but compression is getting raised to 9.2:1 and i'm waking on a raptor sc .
    its my daily driver and gearbox has a 2500 stall and i dont want a aggressive cam
    please help
  23. #23
    VP Berlina LX wagon 5.0L M5
    Dec 2005
    Thanks Greenfoam, I enjoyed reading this thread. Has definitely given me some things to think about, as I am ready to get a new cam, and plan to get one this week. (My engine is in pieces at the moment while I put new seals/gaskets everywhere, so its about to go back together with a new cam).
    I really like the sound of the Wade 963A961A10 cam. I have pacemaker extractors already, and other than a cam, I have no plans for future mods. Keeping in mind, my car is running dual fuel (1 year old mixer setup), would this cam be suitable? As it stands, I get very good economy for a V8, which is good seeing as I do some highway trips. I don't want a cam that will put a huge dint in fuel economy. I am not so fussed when it comes to 1/4 mile times or dyno figures, but am interested in a good all round cam that can deliver good drivability with a stock stall auto, decent performance gain over stock cam without losing too much economy.
    Also, will I get away with keeping my old rockers & pushrods? I numbered them all so I can put them back where they came from. I'll get new lifters obviously.
    cheers,
    James
  24. #24
    VP Executive R-spec
    Jan 2005
    James yeah if you were never to do another mod and plan to drive the car around alot that's the cam (or one similar) I would be getting. It would have a real good chance of better economy than stock. Whatever one you get make sure you paint it with some of that moly spray and also use some cam run in grease and even some crane oil addatives if you can find some, make sure the lifter bores are clean and that the lifters spin good etc. The first start up is pretty important
  25. #25
    Dec 2005
    cheers, thanks for that. i'll talk to wade this week and see what I come up with. I'm 99% sure i'll go with the 963A961A10. Today i removed the old camshaft and lifters. The cam didn't seem to wanna budge no matter which angle i turned it to, so I just turned the engine upside down cos I had it on a stand, so all the lifters would fall out of the way with gravity. then it came out!
    broke my oil pump trying to take it off but a new oil pump cant hurt lol :P
  1. choosing the right oil?
    By Fun_Bucket in forum General
    Last Post: 28-06-2009, 06:48 AM
  2. Need help choosing a set of 20s
    By pepstar87 in forum General
    Last Post: 30-05-2009, 01:42 PM
  3. Help choosing a new TV
    By AirStrike in forum The Pub
    Last Post: 21-04-2008, 11:46 PM
  4. Need Help Choosing Amp!!!
    By Rossgo79 in forum Car Audio
    Last Post: 08-12-2005, 08:54 AM
  5. Need Help Choosing
    By Bubbles95 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2005, 05:30 PM
