im doing the injection conversion blah blah blah and was wondering if i shave the heads and 80thou and manifold to suit will i need adjustable rocker arms or can i use these?HOLDEN 253 308 304 5.0L CRANE CAMS ROCKER ARM ADJ SHIMS - eBay Engine Parts, Engines, Components, Car Parts, Accessories, Cars, Bikes, Boats. (end time 20-Feb-10 10:17:50 AEDST)
hydraluic cam mate
You should be able to get away with non adjustables and a ton of shims.
Reaper
80thou of the heads. ouch. gonna leave then heads awful thin.
Body by Holden, Soul by Brock
the Legend will live forever
LOL, Also a great way to destroy a perfectly good set of heads.
who cares about the heads there worth nothing and this is just a minor build not to last 5000 years and ari why would it ping running and tuning to 98octane fuel and i asked the engine man and he said people have done it all the time and had no probs
o well............
look... its pretty simple. replacing pistons will pretty much mean (if you wanna do it properley) that your crank will need balancing, new conrod pins, conrods crack tested, bored/honed block, zero decked (to get 10:1), etc etc etc
the BEST thing to do, and i am gonna say it one more time, even though it sounds like im harping on, you should just GET A BABY CAM FOR A MILD BUILD ENGINE AND CONCENTRATE ON A BIGGER CAM WHEN YOU BUILD YOUR 383. no need to dick around with flat tops or shaing heads and chasing compression. you can use your stock manifold and stock converter and stock diff and you will still get between 150 and 160 rwkw with the right setup.
otherwise you are building an engine twice.
yep agreed talked to another engine builder today i told him the situation of what the other builder said he replyed no comment so i got ****ed over and made me look like a wanker so the guy said with that cam and 25 thou shave they run fairly good so im doing that no ****n around but will i need shims with that shave? or will i get away with it?
yeah you should shim it. but another mod you will be uber happy with is adjustable roller rockers, hence no need for shims and they really 'free-up' your engine. and plus you can take them off and use them on the 383 later.
25 thou sounds good, i think its safe to go about 40 in those heads cos' the cc is pretty big anyway thatll leave you a bit of squish. but 40 might mean a manifold machine too so cost would be getting up there. so yeah i changed my mind just now, stick to 25.
good to see you are back to looking at realistic mods![]()
