has any body out there changed or modified their intake manifold on a vn to vt 5lt and if so what and what kind of gains made. I cant seem to find a lot on the subject as the LS1 is taking up all the room it seems at the moment. I am even thinking of dual throttle bodies
http://www.starrperformance.com.au/holdenv8_intake.htmlThe Starr manifold and throttle body conversion transforms power and torque of the EFI Holden V8 (VN – VT1), fits under the bonnet, looks standard and flows 1200CFM (standard 580CFM). Best yet, is the price. At $1,450 (exchange), 15kw @ flywheel is achievable by bolting onto a stock 5.0L.
yeah i ahve ported and polished my intake manifold and it does flow better but i havent noticed any major difference. i put a larger throttle body(85mm) on and that started to change my mindi have been looking for a twin throttle body set up for ages so let me know if you find one at a reasonable price!!!
In my opinion the Starr 90mm manifold is the way to go...I reakon to make proper use of a twin TB set up quite a few engine mods are needed & the power/torque band is moved up the rpm range thus...for street use,bottom end torque & power is compromised..fact!!
I read somewhere that the std Holden 5ltr intake system and throttle body set up (single throttle body 65mm) will allowed for power up to 335'ish kw's @ the fly (or around 450hp). this figure was more likely achieved will a high flow filter system.
but even so the star throttle body set up would be the way to go buy fare, if u are that way inclined.
Also if u were going for a ported and polished TB and intake system I’d get my heads port matched. that way u can milk a few more kw's and it will end in a better flow and deliverment of air/fuel to the cylinder.
THERE’S NOTHING LIKE THE SOUND OF A V8 UTE CUTTING CIRCLES IN THE MORNING FROST!!
ive left my manifold stock and port matched/polished/ported my heads and intake and makes a noticable difference on the power sidestill need a chip though.....
just wondering if anybody has used or know that mutch about the
Torque-Power dual plane manifolds or their single plain aluminum manifold
they are around $885.00 inc GST to suit EFI.
they seem to be for highly modified EFI engines.
cheers
http://www.torque-power.com.au
The standard manifold is pretty restrictive, but the starr modifed one does a good job of addressing the shortcomings of the original. The only issue with the starr one is that big 90mm TB lets alot of air in with small throttle openings so will need some skillfull programming to get best results. Port matching is a very worthwhile practice on any manifold for sure.
As for a std engine i would think that there is not much value in changing maniflold. If it is a healthy 160+rwkw engine well then its probaby about the point of chainging manifolds.
as for the vt being any different in manifold to the rest of the range ive never heard of this. mabee different throttle body and runs MAF but maniflod is the same for all accounts.
