Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By Blown V6 Hatch
Thread: lumpy cam for a 308 black motor
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Default lumpy cam for a 308 black motor
    Wanting to get a lumpy cam for the missus 308 black motor what would be the best thing to do??
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Nackerz's Avatar
    Jul 2009
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    how lumpy? lumpy but still civillised enough for a daily driver or something off its head?
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    Nackerz's Avatar
    Jul 2009
    vy2 clubsport
    Feb 2008
    adelaide
    VS 5L M5 VS 6L M6
    Apr 2009
    from experience i can recommend the "blue racer" brand stage 5 hydraulic if u want a cheap cam that suits a daily driver (its a crane cam with a blue racer grind. vpw sell them) specs are 496thou lift, 224degrees duration at 50 thou lift, i forget what lobe separation but its 112degrees +
    i had one years ago in my 308 4speed hq (ported black heads, stock port matched manifold, 650d/p, extractors into twin 2.25in pipes, 3.5 diff gears) it was a good thing, chunky lopeing idle, i dunno how my engine builder degreed it in but it pulled hard to 6 grand, had good torque down low, could drive it like a normal stocker, excellent economy on the highway, not too bad around town if i was nice to it but it was thirsty if i opened it up a bit.
    there are plenty of bigger cams out there but this one has a definate note to it and ya can live with it everyday driving no worries whatsoever.
    Avoid cluey police
    308 vc
    Dec 2010
    North east Adelaide
    Default Sorry about the dig!
    First up:
    1) sorry for the thread dig!
    2) sorry if this has been asked before...
    What cam would people recomend in a stock vk 308 black motor?
    Non re built just a relatively good nic 308 that I'm wanting to cam until I can save for a proper hi comp rebuild..
    After- slightly lumpy idle with a good exhaust note, good mid range power and don't give a snot about fuel...
    Can anyone help me out with some wisdom?
    Wanted to buy VC sunroof
    Pm me
    Jun 2005
    Quote Originally Posted by ajvx01 View Post
    First up:
    What's wrong with the stock cam?
    308 vc
    Dec 2010
    North east Adelaide
    Jun 2005
    No, you want a "lumpy" idle. Contrary to popular belief, the lumpy idle isn't the sole purpose of an aftermarket/performance camshaft. Honestly, if you want to fit a cam just for an idle sound, don't bother as chances are the car will go slower.
    308 vc
    Dec 2010
    North east Adelaide
    And contrary to common belief not everyone asking questions on forums are idiots... Some just like to hear others oppinions who have already done the same thing. Crazy huh?
    I am well aware of how a camshaft works bud, I'm hoping people can say I run a (insert cam specs) and it behaves....
    The main reason is I want more power, not buckets, just a tad more.
    And the fact I like a slightly lumpy idle (not savage mind you) is just a personal taste.
    If you have expertise in the area or experience I'm all ears, I'm not a young punk nor someone who likes to piss there money away. I'm well aware you are right, a lumpy can isn't always a quick cam.. hence asking what's been used before with similar results.
    Pm me
    Jun 2005
    In a stock 308, i wouldn't go any bigger than a Crane 276 (or equivalent). It won't give an overly lumpy idle but it'll run rings around a bigger cam in the same engine. We built a 355 at work and we used the 276, it works really nicely even in a higher comp bigger cube engine. If you want to go any bigger than that, save your money untill you can afford to put a set of flat tops in it and do the job properly.
    308 vc
    Dec 2010
    North east Adelaide
    Thankyou mate that's the exact info, and cam ironicly (atleast I know I'm on the right path) that I'm after.
    As said I plan to run the cam and then build a new motor with flatties etc after..
    So that kinda info is great, cheers...
    If I'm correct that should give good power From 1800rpm? Ie real world rpm on a street stock ish 308?
    Pm me
  15. #15
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    you should get good power around that range from a stockie...
    what else is done to the engine to help it breathe? intake/exhaust/ignition?
  16. #16
    308 vc
    Dec 2010
    North east Adelaide
  17. #17
    VK GRP A rep, VH SL/E, BMW 318is
    Mar 2009
    308 vc
    Dec 2010
    North east Adelaide
    Yea cheers bud I plan to. Currently bumping up the driveline and getting her all schmick then end if year full rebuild I hope..
    Pm me
  19. #19
    SilverVH is offline Banned
    Nov 2005
    There's more than just one manufacturer of cams for the Holden V8.
    Why does everyone instantly refer to Crane Cams like they are the 'be all and end all'?
    If you have a true understanding of camshafts, you should know what lift, duration and lobe separation you want or require and get what you want ground up. Why people bother going to the expense of an off-the-shelf cam for an un-off-the-shelf engine is beyond me.
    Just my 2c anyways.
  20. #20
    308 vc
    Dec 2010
    North east Adelaide
    Well aware bud, I'm getting Mrc to grind me up a custom cam just most people relate to crane..
    I hear ya though chief.
    Pm me
  1. black motor
    By diesellandyman in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-02-2009, 03:15 PM
  2. 308 black motor
    By elegance in forum V8 Development and Modification
    Last Post: 28-11-2008, 11:20 PM
  3. little help please 3.3 black motor
    By 305holden in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-07-2006, 10:32 PM
  4. WTB 308 BLACK motor
    By bumpy in forum Parts And Other Items For Sale
    Last Post: 14-06-2005, 06:58 PM
  5. EFI for black motor
    By mark 70 in forum Parts And Other Items For Sale
    Last Post: 05-04-2005, 05:10 PM
