Results 1 to 20 of 20
Thread: will 308 roller rockers fit 304 ?
    VH SLX WAGON
    Mar 2010
    Default will 308 roller rockers fit 304 ?
    i have a set of 308 roller rockers (yella terra) and was wondering if they will bolt to the injected 304 ? if so what are the pro's cons if any
    thanks in advance
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VK WAGZ 5.0L, GQ Patrol TD42
    Apr 2004
    Port Pirie, South Australia
    I thought they were different (bolt thread) but tried bolting a set we got off some carby heads onto my VN heads and they fit.
    Advantages I guess would be less friction, can handle more rev's, and will give ya more lift if using 1.65:1 rockers.
    VB SL/E
    Dec 2008
    They do fit but depending on specific types (there are several) you should pay close attention to alignment of the valve tip as the exacting tolerances of YT outweigh GMH, with the different valve arrangement between carby heads and EFI heads the centring of the valves are slightly different.
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by VR38 View Post
    But as long as the valve tip is in full contact with the roller it shouldn't be a problem hey? I never checked mine heaps close....but I'm 99% sure they were all ok. Will double check when I assemble the heads.
    VB SL/E
    Dec 2008
    Near enough was good enough for Capt. Cook in 1770, why change now lol.
    But yeah you are right, if the roller is centred on the valve then yeah no prob, maybe a little off with the shaft mount rockers, not sure how close is good enough tho. they will still work but your wear rates will increase alot with high lift and heavy springs.
    ari666's Avatar
    ari666 is offline Jose Arimeintes
    1966 impala, 2011 chevy camaro, 2007 silverado
    Mar 2009
    you want the tip of the roller rocker to be slightly outward of the tip of the valve. the reason being, as the rocker depresses the valve, the tip will roll off the center and inwards. at full lift the tip of the roller must be in the center of the valve stem.
    you can check by smearing a small amount of bearing blue on the roller tip and depressing the valve (crank the engine by hand) whats left should be nice coverage of bearing blue on the valve tip. if its too close to the inside edge you can fix it by either shimming up the rocker or getting different sized pushrods, but its pretty important to get them spot on or there will be too much side loading on the valve and itll wear out your k-lines.
    VB SL/E
    Dec 2008
    Quote Originally Posted by ari666 View Post
    ari666 you are correct.
    Just to clarify I mean centred across the axis of the roller tip, not centred in the actuating plane, if that makes sense.
    DANNY8's Avatar
    Apr 2004
    Well I chucked me donk together just then and put the roller rockers back on for a look (these are yella terra's btw)...and yeah, here's a pic.
    Took them back off and decided to stay with the stock rockers lol.
    VB SL/E
    Dec 2008
    FYI there are two pairs for the old carby heads, two front and two back, if you swap them around does it get any better?
    VB SL/E
    Dec 2008
    I doubt the tips would roll the way you have them pictured and I could only imagine the side loading on the valve guide... especially to the one pictured on the left.
    DANNY8's Avatar
    Apr 2004
    I would go check, but don't really wanna pull the rockers off now that they're on there, all oiled up, and got cam lube on the ends of the pushrods...all ready to go!
    VH SLX WAGON
    Mar 2010
    Cheers for the info guys i will do as said above and check them out. I will let you know how i go thanks once again
    VK V6
    Mar 2010
    NZ
    All the aftermarket rockers I've seen for early heads are symmetrical and fit the same no matter how you swap them around...?
    ari666's Avatar
    Mar 2009
  15. #15
    VB SL/E
    Dec 2008
    It states 2x front and 2x back pairs for each head in Yella Terra's fitting instructions and to check you have not mixed them, don't make me dig them out and quote the actual differing dimensions they state.
    As from the above photo, maybe you did not pay enough attention when fitting.
  16. #16
    VB SL/E
    Dec 2008
    yep, mine are symmetrical, never head of a front or back. if its the case, i guess i just 'lucked it' and got them all right without trying.
    What type are they?
    You may be alright with some other types but not race style shaft mount, they come in the box 4x one and 4x the other and will not line up correctly if installed in the wrong place, it will still work and it is not much but it will wear unevenly on the tip and valve guide.
  17. #17
    VK V6
    Mar 2010
    NZ
    I'm pretty sure its the later (VN) heads that have the different ones like you're describing, not the early heads
  18. #18
    VB SL/E
    Dec 2008
    PFI heads are symmetrical. ie there is no alternating of valve arrangement between the inlet and exhaust.
  19. #19
    ari666's Avatar
    Mar 2009
  20. #20
    VK V6
    Mar 2010
    NZ
    I don't disagree with that, its the slight offset of the valve in relation to the pedestal. There is a photo around somewhere (can't find it at present) which shows it nicely on the Yella Terra rockers, one of each pair has the roller tip slightly off centre
  1. 202 Roller Rockers
    By jakbob in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-12-2009, 07:05 AM
  2. 3/8 roller rockers...
    By pumba in forum Yella Terra
    Last Post: 15-07-2008, 08:08 AM
  3. Roller Rockers LS1
    By minux in forum Yella Terra
    Last Post: 26-03-2007, 05:02 PM
  4. roller rockers???
    By vt_on_20s in forum General
    Last Post: 13-03-2007, 08:57 PM
  5. 1.97 Roller Rockers with cam?
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2007, 11:19 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
