looking at putting a lumpy cam in my vs calais v8!
just got extractors!
Btw i want itt lumpy is there any other cam that i can put in with little to no more work to my car??
any help would be appreciated thankyou!.
You can put any "lumpy" cam you want in with little to no other mods but it will be a slug....
What do you mean by slug?
Slow,
and what could i do ?
stall converter and such?
Big cams need compression and revs to work. Stocko 5 litres have little of both. Big cam = strong torque/power at the top end. So what you will be doing is moving the power band up the range, sacrificing bottom end drivability. Your other bottle neck is the intake manifold which strangles the motor at even moderately high revs. So, in a nutshell, you are going to build a slug as Blown posted above.
Reaper
So better off going smaller cam ?
Thanks mate.
im really looking for the sound and some powerr,
Cheers for the help mate
As Reaper said, stock EFI 5 litres aren't a very good candidate for a big cam, they just simply won't work together....IMO, unless you're going to do it properly, leave the engine stock otherwise you will more than likely end up going backwards.
Stock 304, Guide to choosing a camshaft
Have a look there, that thread it about cams for stock 5 litres, they won't have the choppy idle like you want but the cam will work with the engine.
Thanks for that mate thats been alot of help!
will probably go diff gears instead at this point then maybe work the motor properly!
just put 284 cch cam in my vn v8 cant get it to idle under 2200 any ideas been tyying to adjust air fuel mixture on trottle body but seems to be getting worse
LOL, after your last few "know it all" outbursts, do you really think you're going to be getting any sort of help on here?
cmon being a bit tough on me mate i thought u of all ppl would know how ta get her runnin real good rule of thumb bout 1and a half turn wonce air fuel screw bottoms out yeah that sould be pretty close ay bwown snatch sorry i mean hatch.
Mabye Greenfoam can tune it for you? I hear he's pretty good at tuning 5 litres....
ok ya got his number or is he in the yellow pages ? what was it again
nah got the choke wired shut i reckon might be the point gap to wide measured if me acksaw bwade seem bit to wide i think im getting close thgoe
