Results 1 to 6 of 6
Thread: What dizzy
    GothicKidd's Avatar
    GothicKidd is offline ლ(ಠ益ಠლ
    Series II VR Commodore
    Dec 2010
    South Australia
    Default Some help with Ignition
    Should I get an Electronic Distributor or use the old coil setup?
    The old loom had the resisted wire but that burnt out so I replaced with normal wire and blew the coil...
    Should I get another Coil with Resistor, or just get an electronic Dizzy? One of my parents mate said that if I were to upgrade to electronic dizzy that it would help improve fuel economy
    I was thinking of getting something like this: Click
    What should I do?
    Edit:
    Also... I pulled apart the whole ignition some time ago.. I dont know how to setup the ignition leads, Ive cranked the over till a piston reaches the first sparkplug hole, The mark lines up with the timing scale, but the Rotor ever faces the back of the engine, or towards the 2nd sparkplug.. Is there a problem? :\
    GothicKidd's Ride
    I push the pedal to the floor, smoke them up and go.
    VH SS
    May 2009
    Toowoomba, Qld
    what car are we talking about here mate ?
    I assume it's not the VR listed in 'ride'.
    if it was an old points type distributor, then yes it's a worthwhile upgrade to an electronic HEI distributor.
    Yes you will need to replace the coil with a HEI coil to suit, and remove the balast resistor from the circuit.
    and based on the negative feedback I've read from various sources, I would avoid Procomp parts.
    See if you can find a second hand VC-VL V8 distributor instead.
    GothicKidd's Avatar
    Dec 2010
    South Australia
    Oh Sorry, I was talking about a Hz Kingswood with a 253, forgot to mention.
    I was trying to replace the dizzy with a Electronic dizzy with a coil built into it
    What kind of negative feedback have you heard?
    GothicKidd's Ride
    VH SS
    May 2009
    Toowoomba, Qld
    basically a lot of dissatisfied customers. Part failures, poor quality to the point where parts won't even fit without major modification, parts not performing as advertised etc
    do a 'procomp' search at the big Holden/Ford forums and you'll find plenty of threads on it
    here's just one example, and there are plenty more at that site if you do a search
    http://forum.################.com.au...hlight=procomp
    ah bugger it, why the administrators of this forum feel the need to censor the name of another car forum is beyond me.....
    Just do a search at the S treet Commodores forum
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    yeah mate stay away from procomp & at racing world! i bought a gilmer kit from them......fuc#ed! bought a low mount alternator bracket from them....fuc#ed.....all of which they told me it would bolt on with modifications......BULLSH@T!
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    mate ive just been asking the same thing!
    ari666 got knowledge on this! read my thread on 5.0L efi conversion...posted today!
  1. dizzy
    By hld355 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2010, 08:12 PM
  2. dizzy
    By commy vk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-02-2010, 02:34 PM
  3. HEI dizzy HELP!!!
    By vh2nv in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-06-2009, 03:57 PM
  4. dizzy
    By adrian222 in forum Parts And Other Items For Sale
    Last Post: 03-05-2006, 10:16 AM
  5. DIzzy
    By bigg_vin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-10-2005, 10:43 PM
