Results 1 to 8 of 8
Thread: Strange knock from 5 litre/trimatic
    vr v6
    Aug 2009
    Default Strange knock from 5 litre/trimatic
    I have a strange knock/tapping noise coming from my 5ltr/trimatic.It only happens just after i crank the engine and along as the engine doesnt start(it kind off sounds like dropping a small spanner on the bellhousing while losely holding it at one end).Has anyone had any similar noises coming from there 5ltr?
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    maybe the starter badly adjusted and locking? as it disengages it snaps closed? i dunno. random description get vague answer.
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    yeah mate mines got the same (308 tri). took it to me mech and he said either flex plate/converter or a prolem with the crank and starter....as the boys above said! does it happen when your drivin at normal speed or not? itl only get worse and louder. let me how ya get on with it....as im about to put mine to get it sorted?
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    hey soop! my rear main seal has gone too, aswell as the problem of the flex/converter!
    the mechanic told me all this can be done and fived with only lifting the motor out!
    what are your thoughts to this theory?
    cheers
    Jun 2005
    It CAN be done while it's in the car, but they will probably only do the lower half of the seal (rope seal is 2 piece), which might cure it in the short term but isn't the right way to do it IMO. The proper way to do it is to pull the engine out, pull the crank out and replace the whole seal properly.
    Might pay to ask EXACTLY what they will do before you give them the go ahead.
    vr v6
    Aug 2009
    End up being the starter motor.Had a look today at it ,First i got under the car with a srew driver and cranked the engine(f*%k that was loud)but it didnt make the knocking noise.Then i unbolted the torque converter and spun it ,couldnt hear anything.Checked for cracks in the flexy plate,it seemed allright.Then i started cranking the engine and checking the starter every to time the engine did and didnt make the noise,sure enough every time it made the noise, the starter gear was really close to the flexy plate.
  1. Ping and knock noise on start up VE manual 6.0 Litre?
    By mooks6669 in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-08-2009, 09:36 PM
  2. Strange Knock Type Noise
    By FullySick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2008, 10:16 AM
  3. 6cyl trimatic tailshaft into V8 trimatic
    By SL/E 4 ME in forum VB - VC - VH - VK
    Last Post: 12-03-2008, 08:17 PM
  4. Strange Knock
    By smickvn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2007, 12:59 PM
  5. VK 5 litre Trimatic bolt pattern
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-05-2006, 09:09 PM
