Results 1 to 23 of 23
Thread: eaton112 on stock 5ltr
    vx
    Nov 2010
    terang
    Default eaton112 on stock 5ltr
    putting eaton112 on stock 5 ltr machined banana manifold down aluminium plate on top supercharger mounted so that sides all good. do i need to run a 2bar map sensor i was going to run blue tops standard throttle body about 8psi boost any imput be good cheers for now
    eaton v8's Avatar
    eaton v8 is offline my little sleeper
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    Yep you will need one
    Experience is a hard teacher. First you get the test, then you get the lesson.
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    Skip the 8 psi go 12 to15 at least get a methanol kit it will gain heaps withat as well and it acts as a bit of intercooling as well
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    Put a set of mls gaskets on just to be safe as well
    vx
    Nov 2010
    terang
    ok thanks for response i see you have been there done that yeah just sorting my way thru it all at moment once i get it up and running will look at bigger throttle body 2 60mm set up like you had plus 36lb injectors most of set up is home made so slow going but not gunna rush it any other advise would be appreciated aswell cheers.
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    Pm matt_vp I think he should have a 8psi tune that foam did for me. But I had 42 pounders.
    vx
    Nov 2010
    terang
    oh ok cheers for that least if i get a basic tune its somewhere to start cheers again
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Blue tops in a boosted setup.......good luck!
    Selling FG G6E Turbo and buying a N/A Supra
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    It could be done as long as he had a meth kit for it but I don't have a tune for that. I only used the meth after I put the heltec in it. I have a feeling the blue tops is all mws use in there basic set up but I could be wrong it is only 8 psi or it might have been the white super 6 injectors.
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by eaton v8 View Post
    L67's I would say fair enough, but a boosted V8 with 24lb injectors I would call questionable.
    vx
    Nov 2010
    terang
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    Green tops 42lb you won't max them out well I never did
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    Go on eBay USA not Australia and put in ford lighting truck injectors. Well that what I did I got a set to the door for 250 and they are the 42lb green tops cheapest I found anyway.
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    You just running 98 RON? If so as mentioned look at something like the green tops, if you stay running a low boost they will be fine.
  15. #15
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    24LB/HR Injectors will only see to 300FWHP at 43.5psi fuel pressure 85% duty cycle with a 0.55 B.S.F.C
    42LB/HR will see 520hp.
  16. #16
    vx
    Nov 2010
    terang
    if i get around 300 i will be happy like i said earlier im only taking small steps once i know i can make it run i will look at chasing more power and changing throttle body and bigger injectors the tunes got me worried dont know how to tune for boost thanks again for input guys i do need all the help i keen get
  17. #17
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by sporty custom View Post
    300hp is only 220kw give or take, should make more then that. 300FWHP is only around 225RWHP or 170RWKW......if I had a boosted setup that made 170rwkw I would burn it to the ground.
  18. #18
    eaton v8's Avatar
    Jun 2008
    gladstone qld
    no you won't been there done that boost has bite that has no anti venom I worn you now
  19. #19
    vx
    Nov 2010
    terang
  20. #20
    vx
    Nov 2010
    terang
    eaton v8 just wondering what fuel pump you had and wot regulator you used and at what pressure. i was thinking about getting 36 lb injectors the motors only stock with the usual bolt ons cheers
  21. #21
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    what are these blowers originally off?
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  22. #22
    vx
    Nov 2010
    terang
    ruf 231 there of 2003 2004 cobra or or ar8 falcons yeah yeah i know should be strung up for putting dirty old ford parts on a holden but there actually made by eaton for ford motor company just the end of the casing is different so there a m112 with a ford logo on it but i have a grinder to remove that.
  23. #23
    GTP 85's Avatar
    Aug 2006
    ahh i see.. might look into it a bit more
  1. cobra 2004 eaton 112 on stock 5ltr
    By sporty custom in forum V8 Development and Modification
    Last Post: 16-01-2011, 07:29 PM
  2. [QLD] 355,eaton112,t56
    By eaton v8 in forum Parts And Other Items For Sale
    Last Post: 22-11-2010, 06:44 AM
  3. camtech cam for stock 5ltr?
    By 97VSS2 in forum V8 Development and Modification
    Last Post: 24-06-2010, 09:07 PM
  4. VK Calais stock auto to stock 6 cylinder manual.
    By TheKnightTemplar in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-07-2005, 08:01 PM
