Results 1 to 12 of 12
Thread: Performance mods for my vs clubby
    VS clubsport
    Dec 2005
    Default Performance mods for my vs clubby
    Just looking for ideas for what mods i can do to my vs clubby? starting with just bolt ons for now
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Good service.
    Full exhaust system.
    TP intake manifold and 1000cfm TB.
    In that order.
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Quote Originally Posted by soop View Post
    Good service.
    In that order.
    On a stock engine soop? What the hell for?
    Nov 2008
    Smithton, Tasmania.
    Guessing he's going to want go cam afterwards?
    Either that or leave it stock.
    Jun 2005
    Sounds to me like he doesn't really know what he wants to do though...
    Pistons
    cam
    manifold & T/B
    Should all be done at the same time IMO.
    If you're not changing the pistons or atleast getting the heads shaved for a bit for comp *shudders* just stick with bolt ons.
    VS clubsport
    Dec 2005
    Ok thanks, i keep it serviced well, if i do all of that plus the cam change is it definitely worth getting rid of the stock hsv twin system? and if so what would you recommend for the exhaust? thanks.
    VS clubsport
    Dec 2005
    or screw just bolt ons, just need an idea of where to start first with getting more power out of it, i was thinking of stroking it to 355, then where can you go from there if i want to keep it naturally aspirated??
    Jun 2005
    If you want to stroke it, then do that.
    Be prepared though, that it's not a cheap exercise.
    If you stroke it with some decent compression (aim for an honest 10:1) nice size cam, T/P manifold (either dual or single plain, depends what you're after) 1000CFM throttle body and mabye a little tidy up of the heads it should make an honest 400HP.
    But that'll set you back about $7000-$10,000. That's just the engine, no other driveline work.
    VS clubsport
    Dec 2005
    awesome thanks for your help mate, might go talk to someone at a performance shop to, ive got a budget for now of around 15k for the build whole cars in mint nic to so the engine isnt to tired at all thankfully
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    1. Plugs, leads, dizzy cap, button, coil
    2. Corvette servo if it's an auto
    3. Redback 2 1/2" zorst & a new cat if the old one is blocked (if its more than 10 years old then probably it is)
    4. Tune
    That combo will give you a very respectable car for around $500.
    Reaper
    *edit* - you have $15k to spend??? 355 stroker ftw! 10 - 10.5:1 compression and a TP manifold as above ftw!
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    I'd suggest a 355 crate combo from Pavtek with warranty and guaranteed HP for around $7000.....I believe they are reputable and changeover motor might be cheaper again.
    Warranty Void
    VH SS
    May 2009
    Toowoomba, Qld
    an aftermarket manifold on a stock bottom end is likely to have a negative effect on performance
    nothing wrong with the factory manifold if you only have a stock to mild combo.
  1. performance mods for a vp
    By mrbuntle in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2010, 01:05 PM
  2. Lots of performance questions- 07 Clubby
    By demo9pro in forum LSx Development and Modification
    Last Post: 07-08-2009, 04:57 AM
  3. Performance mods.
    By randomhero365 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-01-2009, 10:16 PM
  4. VX 6 Performance Mods
    By grimavxs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2006, 12:18 AM
  5. Performance Mods for LPG
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-09-2006, 06:10 PM
