Results 1 to 10 of 10
Thread: 355 Carby to EFI conversion
    Vk ls1 turbo
    Aug 2009
    townsville
    Default 355 Carby to EFI conversion
    hey i have just bought a vk calais with a carby 355 stroker turbo 400 and 9". the motor was built to handle boost forged internals and what not. unsure of specs atm as car is still in brissy. i bought it off a mate who has owned it for the last 8 years and built it up. he pulled a 12.8 in it a few years back. anyways i am thinking of converting it to efi as i want to add FI of some sort, supercharger or turbo undecided yet. How much work is involved in this conversion and what parts needed. Are blow through FI setups any good or should i go to EFI. I am unsure what heads i got but will i have to change them if i go to efi. if i go efi i will be using a twin throttle body come manifold. I am not really fussed about the cost i just want the tuffest possiable combo i can get.
    2002 HSV GTO COUPE
    VK calais ls1 turbo conversion (in the build)
    2009 turbo v8 landcruiser
    My VK http://forums.justcommodores.com.au/...-vk-355-a.html
    Vk ls1 turbo
    Aug 2009
    townsville
    also is it possiable fit a 6/71 or something along those line and keep it low enough to put it under a bonnet scoop for street use.
    2002 HSV GTO COUPE
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Vk ls1 turbo
    Aug 2009
    townsville
    i am unsure but i think they might be alloy heads i think. cant get hold of my mate to ask because he is out at work no service but when i get back out to work in a few days i can find out for sure
    2002 HSV GTO COUPE
    ari666's Avatar
    1966 impala
    Mar 2009
    Warranty Void's Avatar
    Warranty Void is offline Take it apart? Me? No!
    VP Berlina LX V8
    Sep 2009
    Some carby inlet manifolds can be fitted with injectors or there is the throttle body kind of injection that looks like a 4 barrell carb and contains the injectors, computer, sensors and all. This kind of system was tested by street machine magazine in the last 2 years with excellent results, you can fit a velocity hat and boost it up later, they're good for economy and driveability and you can use more types of manifold than multi point injection. Some have the computer and sensors built into the "float bowls", some have external computer.
    http://horsepowersports.com/bolt-on-...etrotek-speed/
    This is one system, there are others, you'll want to look around a bit.
    http://www.hotrod.com/techarticles/h...ems/index.html
    Warranty Void
    Vk ls1 turbo
    Aug 2009
    townsville
    Quote Originally Posted by ari666 View Post
    got a pic of the inlet manifold?
    nar i dont have any pics of it its still in brissy i am in townsville i should have it up here soon. just trying to find out the pros and cons of efi and carby with boost for near future planing
    2002 HSV GTO COUPE
    Vk ls1 turbo
    Aug 2009
    townsville
    Quote Originally Posted by Warranty Void View Post
    Bolt-On EFI Systems - The Latest in Fuel-Injection - Hot Rod Magazine
    thanks mate i shall look into this .
    2002 HSV GTO COUPE
    ari666's Avatar
    1966 impala
    Mar 2009
    mate if your thinking about boost, then you may as well go with VN heads. if its running with the old style VK heads, then getting efi to run will be a case of sticking the top end of a VN on and hooking it all up. blower/turbo kits are much more accessable for VN style heads. no one really does the old school kits and if they do they are more $$$
    BUT, you may already have VN heads. who knows. have you seen the manifold on it? is there a huge gap between the front 2 and rear 2 ports, or are they evenly spaced?
    this is VK style. see the gap between the ports?
    this is VN. see how the ports are evenly spaced?
    Vk ls1 turbo
    Aug 2009
    townsville
    oh yea i see what you mean . i have seen it but can not rememeber what the manifold looks like. but as you said i think i will be better off going to efi .
    2002 HSV GTO COUPE
  1. 304 fuel injection to carby conversion
    By nera in forum V8 Development and Modification
    Last Post: 20-09-2010, 03:02 PM
  2. swapping Jets from starfire carby to 202 carby
    By RippleEphex in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-06-2010, 02:01 PM
  3. injection to carby conversion
    By thomas0387 in forum General Discussion
    Last Post: 04-05-2009, 11:04 PM
  4. Carby 308 conversion Qld
    By blingblingbob in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2009, 11:27 PM
  5. Weber Carby Conversion
    By MG's VH Wag in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-07-2008, 10:49 AM
