Results 1 to 5 of 5
Thread: Exhaust wrap for Pacemakers
    Pos's Avatar
    Pos
    Pos is offline BOOYAHHH
    VR Ute 5Lt
    Jan 2010
    Mount Annan, Sydney
    Lightbulb Exhaust wrap for Pacemakers
    Hi all, I'm wondering if anyone has done it themselves, used exhaust wrap on there V8 Pacemakers & how much difference did it make to under bonnet temps & how much did you use? I'm not sure if a 50ft roll is enough for a pair of 5l Pacies for mr VR?
    2009/2010 Sydney Track Champion for Street Fighter!
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    I have heard pros and cons for them.
    Your car will benefit in the short term from lower under bonnet temp and hotter extractor temp but the thermal wrap tends to limit the life of the extractors to about 1 year in most cases due to cracking welds and corrosion.
    Off the top of my head (never have done it) 50 foot sounds plenty enough (although I could be wrong).
    Best RPG ever
    VH SS
    May 2009
    Toowoomba, Qld
    yeah I heat wrapped my pacemakers (against advice from exhaust shops)
    mine lasted more than a year, probably more like 7 years/60,000km before one side cracked big time.
    They overheat, the metal crystalises and cracks
    I'd strongly suggest not wrapping them. Not a lot of benefit for the damage it does to the extractors
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    If I were you I would look into getting them professionally coated as that will do the same as heat wrap and not degrade the extractors in anyway, if not it will make them better.
    I've got some pacemakers on my Vt V6 and within a year they have started to ever so slightly rust in some small patches.
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Ceramic coating will not work the same as heat wrapping. Similar, but heat wrapping is better for exhaust flow as it keeps the headers hotter.
    Don't do it on a street car, you probably won't notice the difference. If you are more worried about engine bay temps, then ceramic coating will be better. But while driving, the temps aren't that bad, it is only while sitting stationary that the temps get up.
    Exhaust flows better through pipe when the pipe is hot, this is why most Japanese cars have insulated exhausts, not to protect anything from the exhaust, but to keep it hot and aid flow.
    Visit my Facebook page
  1. VS SS Exhaust to match Pacemakers?
    By carden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2010, 12:23 AM
  2. [LS1] dual 3" exhaust with pacemakers on auto
    By lethalduck in forum LSx Development and Modification
    Last Post: 13-08-2009, 08:44 PM
  3. VT 5ltr Pacemakers and Full Exhaust.
    By CHEETR in forum Parts And Other Items For Sale
    Last Post: 12-12-2007, 11:15 PM
  4. pacemakers & redback exhaust - fuel consumption
    By Pete284 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2006, 12:00 PM
  5. Header/exhaust wrap questions
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-03-2006, 10:39 AM
Tags for this Thread
