Results 1 to 20 of 20
Thread: Diff gears/stally with cam
    GMHCalais is offline [TUKN20Z]
    VY SII 5.7 Calais, VS SS SII HSV Enhanced
    Jul 2009
    adelaide yo
    Default Diff gears/stally with cam
    hey all. Im buying a crow cam 4503 and just wanting to know if chucking a stally and diff gears Will improve torque and power? The cam starts in at 2200 and finishes as 5500 if i remember correctly. Anyone got any advice as to what is a good combo? Also what type cams fit into series one and two vs ss's? Cheers
    Slammed 5.7 VY calais II tuckin G8 20'z
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    you'd want some compression to help get the best out of it. It's pretty close to a Crane 286 and they can go backwards on some stock engines... others can sound good but not make a lot more poke than an engine with bolt ons
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    I'd definitely go a stally. I think the cam goes from 2500-5500. I'd prolly go a 3000rpm stally, just because sometimes they don't flash right up depending on how much power ya making. As for diff gears, it depends on wat ya wanna do I guess. I put 4.11's in my wagz coz we built it to go in skid comps, but also wanna cruise around in it and the 4.11's really #### ya off on the highway coz ya sit on like 3000rpm on about 90-100k's. But yeah really depends on wat ya wanna do and how ur gonna use it. If it's just town driving and ya want good acceleration then yeah 4.11's, but like I mentioned b4 they get annoying on the highway, so if u plan on doing a fair bit of highway driving maybe go 3.9's.....which still wouldn't be good on the highway, but ya don't build a hot motor to have good fuel economy do ya... lol
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Jul 2009
    adelaide yo
    Quote Originally Posted by DANNY8 View Post
    Yeah nah i for sure wanted to chuck a stally on it, just wanting to get some info. How would i get some compression into it to get some good results back.
    Jun 2005
    Put a set of flat top pistons in it. Alternatively, if you're after a cheap and half arsed band-aid type fix, you can have a heap shaved off the heads.
    With most aftermarket cams, 10:1 compression will work well.
    Jul 2009
    adelaide yo
    Anyone know of a good place that does shave heads or sells cheap flat tops?
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Quote Originally Posted by GMHCalais View Post
    ACL flat tops....are the go...pretty easy to source..id go the pistons and new rings. at least your compression wont drop with a new set rather than shaving the heads! hunt on ebay for the pistons
    DANNY8's Avatar
    Apr 2004
    Miltons have a good reputation, I'd go there.....well my donk IS there lol. 48-50 Main North Road, Prospect.
    You're a week too late! I just sold a set of 30thou ACL flat tops on ebay for $300.
    Jun 2005
    Quote Originally Posted by mr j-man View Post
    Please explain, how will the compression drop by shaving the heads?
    Jul 2009
    adelaide yo
    haha! always the way isnt it!!
    Ve SS
    Apr 2011
    Diff gears/stally with cam rules...My brother used to have BA XR8 with 4.11, 3000 Dominator Hi-Stall converter and stage 2 crow cams...It was a beast but the fuel economy wasn’t the greatest. He used to get somewhere between 270-300km out of full tank…
    Jun 2005
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    [/B]
    it still increases comp but I think he means when you shave any set of heads the chamber bowl area becomes a different shape so it needs to be reworked to get the most out of it
  15. #15
    Brendo169's Avatar
    Brendo169 is offline HSV Porn
    VS Senator
    Aug 2009
    WA
    put some 3.9 diff gears in and a 3000rpm stally....along with the flat tops and cam.....will definately wake you up!!!
    ive always had diff gears but only just recently put on a high stall and im now wishing i did that years ago!!
  16. #16
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    [/B]
    shaved heads with stock pistons and rings! as u know shaving heads increases compression right! increasing compression increases heat and strain upon combustion on a stock ring and piston especially when it reaches TDC. So a stock piston/ring depending on its age that isnt designed for the higher ratio - over a period of time your definately garaunteed to lose compression through the weakining of the old rings depending the age and newly designed ratio! (heat of compression) and (piston fit)......mechanical engineering.....why do u think they lower compression ratios when forced induction is used....to eliminate excessive heat and impact at TDC...just to name a few
  17. #17
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    i have never heard such utter crap in all my life.
  18. #18
    Jun 2005
  19. #19
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    This thread reminds me of the hot rodder's mantra:
    Cheap/Reliable/Power - Pick 2.
    Do yourself a favor - think thru what you want the car to do and then go visit a good engine builder who can put together a combo that will do the job as a system. Just throwing random bits together will most likely end up with an ill manored pig that will be slower than a VP V6 (granted they are faster than most things on the road - just ask anybody who owns one!)
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
  20. #20
    Jun 2005
    Reaper
    No way Reap, VN V6's are faster, everybody knows that....
    But seriously, 100% agree with that post.
  1. [SA] WTB- 3.89 diff gears to suit borg warner diff
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-05-2010, 01:23 AM
  2. !change of top speed in gears when fitting 3.7 diff gears.!!??
    By slappedvr in forum V6 Development And Modification
    Last Post: 30-01-2010, 09:54 PM
  3. stally, trans or diff?
    By callum_88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2009, 08:13 PM
  4. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
