hey!
some one told me on this forum that a TH350 trans was the same dimensions - ie: length.
as a trimatic and should be able to use the same tailshaft from the trimatic in a vh!
The t350 is 110mm bl##dy longer.
Wat crossmembers are suited to fit a th350 in a vh commodore?
or should i not ask as some people dont know what they are talkin about on here!
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
cheers for the rare spares info...i had a feeling they did them but hadnt had a chance to check em out!
theres isnt any attitude! people shouldnt comment to questions they really dont know the answer for! would u answer someones question if u didnt know the answer?.... i know i wouldnt!
thanks anyway
"Practical knowledge is worth 5 times as much" in deed it is...but thing that gets me is the fact people answer questions that they dont know the answer for...as i said above. and never dealing with a th350 before i thort i mite come and ask a few questions.... i dont really care that its longer......but i had not 1 but more than 4 people tell me it was a direct changeover, so u tend to think they are right!
castlemaine rod shop (CRS) also sell crossmembers.
i dunno what the go is with your T350 being longer than the trimatic, i'm pretty sure i was one of the blokes who said it would fit up ok. i know when i did the swap in a vh sle that was still running the original factory 308/trimatic i had to use an adaptor plate, say 1/2 inch thick. and my stock tailshaft still fitted but only just.
i just went and measured up a T350 and a trimatic of unknown origin, from the top centre of the bellhousing face to the end of the extension housing is 725-730mm on both. j-man is your trimatic shorter or T350 longer than this?
I think i can solve this mystery...There are about 4 different extension housings (that i know of) on a TH350, they're all different lengths. Pretty sure the shortest is the same length as a Trimatic, obviously all the rest are longer. It's quiet possible that the OP has a long extension housing TH350. Hence the problems with the tailshaft being too long.
OP, no need to be a smartarse mate, remember at the end of the day you're asking on an open forum, no one knows everything....
you dont need a custom cross member, grab a 6cyl trimatic cross member
http://www.youtube.com/watch?v=rute6aV3nN0
Top gear @8500rpm
