Results 1 to 6 of 6
Thread: Conversion!!
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Default Conversion!!
    Hey!
    Im currently in the middle of doin my conversion on my Vh Sle from a 308 and trimatic box to a 5.0L efi with a Th350. As u may know the 308's powersteering pump is on the passenger side.... and with the 5.0L it is mounted to drivers side! I Plan to run it with pwr-steering (Original steering rack) and was wondering what to do with the hoses from the rack to the pump in regards to installing the new pump to the driver side!....do i switch the alternator with pwrstr pump or is there some thing u can do with the hoses???? i know there is a few of u out there that have done the same conversion so all help appreciated
    cheers
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Not really sure bout this, but worst case is youll have to get some lines made up to run around the motor to the other side, prob tidyest to over the back of the motor around the bell housing.
    Reaper
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    fit the vh powerstearing pump and alternator
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Quote Originally Posted by delcowizzid View Post
    thought about it but the alt bracket and pwr pump fom the 308 are pretty sh#tty and would like to keep everything mounted in correct posistion.
    the VH alt bracket is the chunky one with th a/c mounts.
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    Quote Originally Posted by VrWagz1 View Post
    the pwr str pump i have on drivers side (new posistion) and the pressure lines tap into the rack beneath the steering shaft (original connection) so itl be a more or less straight run from rack to pump.
    VH SL/E 5.0
    Oct 2010
    Six Feet Under
    just wondering whether it would be possible to run vn-vr pressure lines between the 2 points both connected on the driver side
  1. L67 conversion OR 5L conversion in vs commy??
    By triple b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2010, 11:54 PM
  2. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  3. Vs dash conversion - Firewall - ecotech swap - vs stato front end conversion
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2010, 10:51 PM
  4. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
