Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By VKCOMMO
Thread: Cleaning Intake Manifold
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Default Cleaning Intake Manifold
    How can you clean inside the runners on these manifolds? I rang a local engine place and they didnt want to checmicaly clean it for some reason they gave me about it eating it away.
    In that case how do you do it? Already done degreaser, then high pressure cleaner etc. Just want to get the oil/carbon build up off them.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    WL Caprice & VQ Stato
    Feb 2011
    Seaford
    me and a mate used Gasket Stripper from CRC on his ecotec inlet manifold, foams up for a bit then when just hosed it off, was good for the places we couldn't get with kero or carby cleaner earlier.
    its a bit more expensive than most other things from memory but worked much better than we guessed it would lol
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Thanks, i might give that a go on the weekend.
    Another quick question, whats the stock rating of the 304 injectors? Ive been told to get some LS1 injectors that are 24lb to put on the 355. Dose anyone know if these are these are a stright fit?
    The Daily VN T5V6
    355 VN GRP A REP
    vy calais .vs commodore
    Sep 2005
    blacktown
    Feb 2011
    Seaford
    Quote Originally Posted by bulldog79 View Post
    oven cleaner works well
    true! I don't use my oven much tho so didn't have any laying around lol
    not sure on the injectors tho mate, would be nice to know if they do for when i get the VQ back together........one day
    Feb 2011
    Seaford
    VH SS
    May 2009
    Toowoomba, Qld
    Quote Originally Posted by mischa View Post
    I used this stuff.
    Worked a treat.
    Alibrite 5L, Septone Products Australia
    be very careful with oven cleaner, most oven cleaners contain costic which dissolves aluminium
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Yeah engine shop is correct you cant cvemichally clean alloy hydrochloric acid eats it away.
    Bead balsting after a good clean can help get rid of stubborn stuff wont reach all way through runners but should get a fair bit
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    smischa i just shoved the big work gurni up the runners, then bought a solid bottle brush and put it in the cordless drill and ran it up and down the runners.
    Reaper
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Quote Originally Posted by Darren_L View Post
    I used this stuff.
    Worked a treat.
    Thats more like it, i might try to get some of that then.
    Quote Originally Posted by D-Renzow View Post
    just found this ls1 injectors ona 304??
    Thanks, did see that but wasent sure if that person managed to get them to fit. Super6 ones also fit apparantly.
    Quote Originally Posted by Pub247 View Post
    Yeah looking for somthing I can do at home now tho.
    Quote Originally Posted by VrWagz1 View Post
    Might give that a try with the Alibrite, thanks wez!
    The Daily VN T5V6
    355 VN GRP A REP
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Pfft.. Just fill the bastard with carby cleaner and leave it to soak
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Dont you think ive done that jack! Left it overnight and it didnt work!
    The Daily VN T5V6
    355 VN GRP A REP
    Feb 2011
    Seaford
    yeah I tried that, doesn't work to good when its almost black lol, then did the gasket stripper for about 20mins then hosed it out.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Lol. Just checking
    How about lots of coke (as in cola)
    I've used it to dissolve gun powder (cleaning a cap gun) so it might do your manifold justice...
    Just a thought....
  15. #15
    VrWagz1's Avatar
    May 2008
    wollongong
    Quote Originally Posted by VKCOMMO View Post
    Lol. Just checking
    Just a thought....
    Glad you clarafied that, that would be one hell of an expensive manifold
    Reaper
  16. #16
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
  17. #17
    dobesz's Avatar
    dobesz is offline 355ssute
    vs ss ute
    Oct 2009
    I cleaned my Walky manifold with a bead blaster, came up a treat. Runners are like new. And yes the blue tops (ls1) swap straight over. U need these for a 355!
    MUNCH MUNCH LS1 4 LUNCH
  18. #18
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    vn grp A
    0 280 150 706
    186.7G/min@3bar 2.5barOP 15.9ohm
    Blue top vr,vs,vt 5.7
    0 280 150 775
    186.7G/min@3bar 3.3barOP 15.9ohm
    Bosch PDF
  19. #19
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    355 VN Group A Replica
    Ill get some pics and let you know how it goes.
    The Daily VN T5V6
    355 VN GRP A REP
  1. cleaning manifold, TB and radiator.
    By impulsive in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-05-2010, 11:37 AM
  2. intake manifold
    By stevesvx2001 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2010, 05:05 PM
  3. air intake manifold
    By willyk in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2009, 08:58 PM
  4. V6 intake manifold
    By VPCalais38 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2008, 03:27 AM
  5. is it worth cleaning the inlet manifold on a series 1 vn?
    By jas98 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2007, 01:12 PM
