Hey all,
Some of you might know im Supercharging my Vr Ute...........
Just a question on the oil feed line, does it have to run from where the orig oil switch was or could i get one of them oil Filter Adaptors and run the oil feed line from that and leave the oil switch where it originally is on the oil pump.
Im going to get one of them Adaptors to allow me to run my Oil Pressure Guage......
94 Red VR 5 Litre 5 Speed Super Charged and intercooled = Alot of fun!
I'm not sure a sandwhich plate would work for that, could be wrong. I'd just use a t-piece where the oil switch goes, so ya can run the switch and also the line for the blower, if ur gonna run a gauge as well, look for sumfin with another outlet on it as well.
Another idea which is prolly a bit overkill just for an extra oil feed line is to get an oil filter relocation kit, as some of them have extra feed lines in them, and come with fittings to block them up if not in use.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
