Hi guys. I need some help choosing a cam for my engine. Now I will be using it for drag racing until I get off my p's then I'll drive the car on the street. Here is a run down of what my motor has-it's a vr 304,factory clearanced for stroker zero deck height, 10.5:1 comp,30 thou over, arp main studs, speed pro forgies, a9l's with arp bolts, balanced etc it also has a dual plane high rise manifold with a 1000cfm billet throttle body.
Can anyone help me out? Cheers
Red 1985 VK Berlina Commodore
My donk is very similar, except using a Torque Power single plane hi rise manifold, a Holley 750dp, and it has 10:1 compression. I'm using a Crane F280 solid. My motor is built for street use, burnouts and wouldn't mind taking it down the strip also. Apparently the F280 has run 10's in Commodores.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
280 solid is a good choice mate, will be an angry street car but you need head work! Do you have head work? Dont think u will be running tens with the 5l tho. U want at least 300kws at the rears for that!
Prob make 240rwkw in a 5l. Stroke it and its a diff story!
Nah I'm not expecting to make 10's with mine. Hoping for 11's. But yeah mine is still stock stroke 308 with stock VN heads. Hoping for anything above 250rwkw.
The heads have just been reconditioned so no modification. What sort of headwork should I get done to them? Just port them?
Yea just mild porting polishing removing harsh bends etc. As heads flow something like high 400 horse standard!mmmmmmm 250rwkw is a lot from a 5l. My friend made nearly 250rwkws and has done a shit loaf of work to it! I hope to male 240rwkws withy 355 but it's my work ute
MUNCH MUNCH LS1 4 LUNCH
Ok thanks guys. Where can I get a 280 solid cam from? Also should I get new springs and lifters or leave the stock ones?
yeah mate 280 solid cam, solid lifters to suit, 3500 stall, yt roller rockers, flow the heads to 350-400hp, good ignition and a good diff gear setup and your laughin! i had all this and more in my 308 and it was f##king angry as f##k! was a carby motor too. i highly recomend the crane solid 280.
Yup but should speak to an expert first as buying all the fast bits doesnt always mean it will be a good motor etc! Dont want miss matched parts.
Crane have a web site check it out as it will detail engine specs needed for 280 solid!!
Yeah mate I have a compression of 10.5:1
you will need diff gears for for that cam. plus adjustable roller rockers. manual or auto? if auto a 3.5-4k rpm stally.
248 duration is not baddoubt you will want to drive it on the street much. unless you have shares in BP. this thing will make some good fun power @ 4000rpm
