Results 1 to 7 of 7
Thread: manifold?? tb??
    hz
    Apr 2011
    ferntree Gully
    Default manifold?? tb??
    is the starr manifold set up worth it or should i get myoriginal manifold honed and get a bigger tb?, if so what size tb?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    worth it? NO
    Yes if second hand and cheap
    I had one with h/c combo gained around 20rwhp personally for the price the come is the better option but for a even cheaper option go the Harrop or torquepower single plain with a four barrel 1000cfm throttle at least they look good
    hz
    Apr 2011
    ferntree Gully
    what did you change yours to? was it that set up? Suppliers? would love the feed back, roller rockers worth it?
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by Atrain View Post
    I sold the car so I didn't get a chance to do the single plain 4 barrel setup, roller rockers aren't really needed but it does come down to your setup
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    What are you trying to achieve?? What do you use the car for?? What other mods are done to the motor?? What rev range do you operate it in??
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    hz
    Apr 2011
    ferntree Gully
    baby cam, set of pipes, 2.8 stall, shift kit, electric fan, 3.25 gears. its not my daily but not aimed at the track either, some where in between. Im pulling the heads off to remove de-comp plates so i was thinking while im at it...............................
    Munz's Avatar
    Jan 2011
    Brisbane NTH
    I think get your heads ported while there off nothing better than a ported set of VN style heads
    How is your cars cooling with an electric fan my car used to heat up bad with the single 16in thermo had to switch to the twin AU thermos @ 3000 cfm of air
  1. [VIC] LS6 Manifold
    By Galixia in forum Swap / Wanted to Buy / Trade
    Last Post: 12-07-2009, 04:33 PM
  2. Oh NO Manifold!
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-11-2006, 04:25 PM
  3. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
  4. oil in manifold
    By 9898989 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-12-2005, 11:34 AM
