I'm trying to find out a rough estimate of how much flywheel kw a stroker 355 put out ?
I tried searching but didn't find anything helpfull
You probably didn't find anything because the question is so open. Depends on camshaft, heads, manifold, tune, fuel.
So based on that, well go with anywhere between 200kw to 700kw.
Hot Lap Motorsport
Pretty sure the holden stroker was 215 @ the fly
no, the Holden 215i Stroker was a 350ci, 5.7litres, 355ci = 5.8litres
Factory Holden strokers are 350 cubes, it's the 30 thou overbore of a re/built stroker that makes them 355 cubes.
all above is correct....typically a built stroker will make more power than the holden factory stroker
My Senator 355 Stroker
http://forums.justcommodores.com.au/...5-stroker.html
